Belt squealing loud from the alternator
I switched from a 2G to a 3G alternator (160 amp) on my 351W and it seems that the belt isn't able to turn the heavier alternator fast enough and the belt squeals. At the same time I made that alternator change, I also replaced the stock fan with an electric fan.
Would this mean I need to adjust the belt or that I need a new one? I thought about adjusting my tensioner but wasn't sure which way - https://i.imgur.com/jUCDe.jpg
You could put an underdrive pulley on it and have more mechanical advantage.
With the serpentine setups most people just go to an 8 rib belt. (but that means changing all the pulleys)
I did find an idea in this thread. https://www.ford-trucks.com/forums/1...dea-tdr-p.html
This isn't a little noise, it's a lot. And it doesn't seem to go away after sartup. Also, this is using the stock 6 groove belt, not a v-belt.
Yep, I know what you said.
Take the belt off and spin everything individually looking for any component that might be stiff or crunchy.
Perhaps the tensioner spring is getting weak after all these years?
A larger pulley will help the mechanical advantage without affecting output much except at idle.
The guys that really use high output 3G's for winches and the like, usually go to an 8 rib belt.
Thanks.
Other then crank pulley, 8rib pulleys are easy to find. They are on all powerstrokes and sc lightning and sc cobra and 99+ f450-550 or even tbird supercoupe
Then Paxton or vortec sell 8rib for mustang apps so maybe it will lign up with truck acessories.
Larger diam pulley is what's needed. Not enough belt wrap for the draw. I put a "100amp" replacement on my truck and all it was I think was my 85a with a smaller pulley. I'm happy only cause it charges better at idle, but I was hoping I didn't need to go with a 3G. New rebuilt on eBay only cost 40 shipped and no core. I'm not concerned. I'll keep my eyes open for a cheap 3G. May score a new one at jy in a few weekends.
So far, so good. But I only had the truck running for ~30 seconds or so - I'll play around more this weekend. When I started the truck, the new belt squeaked a little but eventually things caught up and at a steady 1000 RPM (cold idle) I was getting 14.2 volts, 1 volt more than last time with the older belt.
Thanks!
Thanks!
vroom9
08-02-2020 10:18 AM
fballguy
06-06-2019 03:21 PM
optikal illushun
13
05-02-2009 03:57 AM
