4x4 Conversion In Progress
#46
#47
And that works.
On a side note, I'm having the rear driveshaft fabbed up by the local 4x4 shop.
Using the rear driveshaft from the extended cab long box Donor truck.
It's a 2 piece driveshaft, but we measured how long we need it to be, and are going to have the shop weld the 2 shafts together. With the 4x4 transfer case slip yoke on the front of it, and the 2wd rear end fixed yoke on the back of it. Total cost will run about $350.
#48
#49
Front diff takes 75w90 gear oil, 3 qts.
Trans takes dexron/mercon, about 7 qts for a pan drop/filter change, more if you've drained the converter. I'd get 12 qts, or two five gallon bottles and flush it.
Transfer case takes the same dexron/mercon, 4 pints.
Also, on the driveshaft, is there a reason you can't use a junkyard driveshaft from a 4x4 longbed regular cab pickup?
#51
And yeah that would probably be the easier way to do it, just getting a driveshaft from the junkyard, but I'm just using what I have right now. Shouldn't cost much for the two shafts to get welded together, I don't think it'll be anywhere near $350.
Thank you!
#54
My issue with trying to find a junkyard driveshaft was that not only did the truck have to be a f150 londbed 4x4, it had to have the same tranny in it as well for the length to be correct I believe..
Minnesotafisherman: is there a reason your having them weld the two piece axle together rather than just shorten the one from the extended cab? Maybe I was doing my measurements entirely wrong... but with the tranny transfer case combo being approx 49.5" vs. 30some for the 2wd, the extended cab one piece driveshaft was just about 3" too long to fit.
#55
#56
Monroe Reflex Shocks came...
Notice one of the front shocks came with 1 bushing short... and one of the rear shocks had the wrong sticker put on it, so they put the correct one right over it. Can definitely tell these were Made in the USA
And center caps:
Only going to use 2, just for the rear tires, since I have lockout hubs now, can't put caps over those lol.
And center caps:
#59
Alright guys, changing all 12 quarts of the tranny's fluid, and the Transfer Case's 2 quarts. So I need 14 total.
What should I go with?
Valvoline.com > Products > Automatic Transmission Products > Automatic Transmission Fluid > MaxLife® DEX/MERC ATF
AMSOIL - Synthetic Multi-Vehicle Automatic Transmission Fluid (ATF)
Automotive - Royal Purple
#60
