Rear end axle hub nut torque - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 07-01-2012, 04:32 PM
sand_fiend's Avatar
sand_fiend sand_fiend is offline
Work in Progress
sand_fiend has a very good reputation on FTE.sand_fiend has a very good reputation on FTE.sand_fiend has a very good reputation on FTE.
I have a couple of questions.
I replaced a bad leaking rear axle seal.
my book is hard to fallow on instructions
The book says to pack the bearings. docent the rear end lube them ?
Im using the old bearings. they looked good. no discolor or pits.
then it says to torque the ratchet nut to 60 Ft lbs and back off 7 clicks for used bearings.
the only thing i didn't do was pack the bearings when i pit it back together
i have not driven the truck yet. should i pack them or is it ok because there was no grease in them, only oil when i pulled them out.
and is this 60 lbs and 7 clicks back right ?
Old 07-01-2012, 07:23 PM
sand_fiend's Avatar
Work in Progress
Ok, I guess being over medicated is better than living in pain.
Pulled it apart and packed the bearings and did the 60lbs and 7 clicks back
Old 07-02-2012, 10:00 AM
Krewat's Avatar
Krewat Krewat is online now
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
My manual said to put gear lube on them, I still used some grease anyway... You need to put something in there because until you drive it and make some turns, gear lube won't work it's way down into those bearings.
But yes, that sounds right - 60 ft/lbs, 7 clicks back. I would spin the hub while doing this just to make sure the bearings are fully seated.
I just did one of my rear bearing seals...
Rear Wheel Bearing Disaster sunogbahay 1999 - 2003 7.3L Power Stroke Diesel 5 10-12-2016 05:50 PM
installing new rear bearings. (01 DRW) PEI 1999 - 2003 7.3L Power Stroke Diesel 0 09-21-2012 05:01 PM
Dana 60 rear axel nut torque specs 79str8six 1973 - 1979 F-100 & Larger F-Series Trucks 4 03-20-2011 12:49 PM
wheel bearing adjustment ac700wildcat 1987 - 1996 F150 & Larger F-Series Trucks 4 04-28-2010 05:24 AM
F250 Superduty 2WD Wheel Bearings FlyinFord 1999 to 2016 Super Duty 7 10-23-2009 09:23 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
