Go Back   Ford Truck Enthusiasts Forums > Other Fords > Ranchero & 1961 - 1967 Econoline
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 07-01-2012, 03:17 PM
chamblizi's Avatar
chamblizi chamblizi is offline
1975 Ford Ranchero
chamblizi is starting off with a positive reputation.
75 Ranchero Shifting at 30 mph (HELP)
Hey its Phil i got a issue with my ranchero shifting at 30 mph it use to shift at 20 wtf is going on!
this is why i don't like mechanics touching my truck.....
It started shifting at 30 after he changed the carb and he bent my throttle bracket and i had to bend it back for the gas peddle to sit where its suppose to.....
this is some BS...
__________________
"I'll learn my self, where is my beer!"
  #2 (permalink)
Old 07-03-2012, 11:10 AM
jas88's Avatar
jas88 jas88 is online now
Garage is empty, add now
jas88 has a good reputation on FTE.jas88 has a good reputation on FTE.jas88 has a good reputation on FTE.
There is a bent rod that goes from the carb to the trans to tell it how hard you are pressing on the throttle. It's called the TP rod I think (TP stands for Throttle Pressure). Sounds like it needs to be adjusted.
__________________
1974 F350 Wrecker 360/T18
1991 F150 SuperCab 4x4 7.5L/ZF5
1991 Bronco SAE 7.3L IDI/ZF5
2005 Escape 2.3L/CD4E
  #3 (permalink)
Old 07-03-2012, 12:08 PM
chamblizi's Avatar
1975 Ford Ranchero
Quote:
ok how far down does it need to be when it reaches full down position that is concidered when it will shift right?
__________________
  #4 (permalink)
Old 07-03-2012, 01:37 PM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.
  #5 (permalink)
Old 07-03-2012, 03:16 PM
chamblizi's Avatar
1975 Ford Ranchero
Quote:
Originally Posted by 85e150six4mtod View Post
Did you ever run down the modulator vacuum line?
http://www.ford-trucks.com/forums/11...from-4bbl.html
not yet i still got to clean the hell out of my stuck lifter.
__________________
  #6 (permalink)
Old 07-06-2012, 11:35 PM
chamblizi's Avatar
1975 Ford Ranchero
I am getting ready to check out the vaccum modulator asap, Just got done with reinstalling the original rocker arm and push rod with the addition of a new rocker arm bolt. I also cleaned the passengers side cylinder head with some bardhal motor/tranny flush.... man she is so silent in her valve cover not even a bug can hear it..... XD
When that flush stuff came out.... my oil looked like bubbly watered down tar. It was 5quart when it first went in by time it came out it had gotten so thin that it was 3 quarts in the jug i dumped it into.
New spark plugs set to 0.44 spec... the prior spark plugs that where put in where gapped wrong by my friend ..... they where set to 0.39... i made those mistakes before too kind of funny.
I got to jack her up and find that modulator now.
__________________
  #7 (permalink)
Old 07-06-2012, 11:39 PM
  #8 (permalink)
Old 07-07-2012, 12:12 AM
chamblizi's Avatar
1975 Ford Ranchero
[quote=85e150six4mtod;12032138]Remember the mission here is to confirm the modulator is connected via vacuum line to the carb. Don't pull the modulator off the trans just yet.[/quote
it should be a small line but i got to fallow it up the engine, Thats the only way i will know what i am doing... i think its just hooked up wrong.... I like to trace things down.
thats how i learned my wiring system in my ranchero since i cannot read a diagram
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
