Codes Codes Codes
Old 07-01-2012, 02:22 PM
95350PS's Avatar
95350PS
95350PS is offline
Codes Codes Codes
Ok just used my superchips 1705 tuner to read codes and im getting these codes
P0603- internal Ctrl Mod KAM error
P0235- turbo boost sensor A Circuit error
P1280- ICP Circuit Out of range low
P0122- Throttle Pos Sensor/Switch A Circuit Low Input
P0221- Throttle Pos Sensor/Switch B Range/Perf
what to do what to do if its not one thing its another
Hopefully someone can bring light to these codes for me and help me out on what i need to do about them.
Thanks again guys your help is always great
Old 07-01-2012, 03:07 PM
baker1983's Avatar
baker1983
baker1983 is offline
The icp i would clean the sensor top front driver side head
Old 07-01-2012, 03:08 PM
Action4478's Avatar
Action4478
Action4478 is offline
How is it running ?...
Old 07-01-2012, 03:09 PM
baker1983's Avatar
baker1983
And make sure your oil isn't low cause if im not mistaken it has to do w the oil but some one that knows a little more then me will prolly chime in here soon if i am
Old 07-01-2012, 03:15 PM
fordpride's Avatar
fordpride
fordpride is offline
P0603- internal Ctrl Mod KAM error - this is most likel form dissconnecting that batteries or cause off the programer don't worrie about it
P0235- turbo boost sensor A Circuit error- not sure
P1280- ICP Circuit Out of range low- unplug the sensor and look for oil in the plug
P0122- Throttle Pos Sensor/Switch A Circuit Low Input- not sure but these two might have something to do with you tran acting up
I added answers
Old 07-01-2012, 03:19 PM
95350PS's Avatar
95350PS
95350PS is offline
Runs fine as far as i know only issue im having is a tiny slip in the tranny nothin horrible though
Old 07-01-2012, 03:20 PM
fordpride's Avatar
fordpride
That slip your feeling could be the go pedal cutting out for a split second
Old 07-01-2012, 03:23 PM
fordpride's Avatar
fordpride
With a good mutimeter you can test the TPS
Leave TPS plugged in and key in on position
Set meter to volts
Put hot lead in the middle wire on the TPS plug from the back side of the plug where the wires go in
Ground to battery
Then slowly push the go pedal down watching the volts to see if you have a dead spot in the TPS
Old 07-01-2012, 04:34 PM
95350PS's Avatar
95350PS
95350PS is offline
Good idea mike that could be my slip ill have to check that this week when i can get my hands on a multimeter
Old 07-01-2012, 05:21 PM
Action4478's Avatar
Action4478
Isn't a slip an RPM increase & a flat spot in the TPS an RPM decrease ( more often described as a stumble)?.
Old 07-01-2012, 05:48 PM
fordpride's Avatar
fordpride
Yes it Rick but I had a TPS issue that had me all over the place. Sometimes it would feel like a slip and other felts like a miss but you never knew when it would happen and when it did it was do fast that you really didn't know what to make of it. So that's why I said check the TPS
Old 07-01-2012, 06:02 PM
Action4478's Avatar
Action4478
Sorry about that ,, An RPM increase from a bad TPS is a new one on me ...
To the OP , If you have cruise control , you can try driving it with that to rule out the TPS as well...
Old 07-01-2012, 06:18 PM
95350PS's Avatar
95350PS
95350PS is offline
Cruise works fine besides the coast it stumbles when using the coast button and seems to cut out but no cruise on decel does just fine
Old 07-01-2012, 06:33 PM
Action4478's Avatar
Action4478
I didn't quite understand what you were trying to say ..Sorry
Old 07-01-2012, 07:06 PM
Action4478's Avatar
Action4478
If you can , run the truck till you can use the cruise control. Run the speed up & down with the steering wheel control. Look for flat spots or RPM changes .
I'll leave it to Ford pride from here ...
Quick Reply: Codes Codes Codes
