You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
hi to all
i have an 02 excursion diesel 7.3. my question is
what do i need to do to bleed the fuel system to have it start when i run out of fuel and refill the tank
this has not happend just a question that i wanted to know
Put some more fuel in and turn the key on, open your drain valve on the water separator until fuel starts draining out. Fire it up and it will run rough for a few miles and then you're good to go.
__________________
John
2001 7.3 F-250 LB 6sp. Dump bed, Firestone air bags, DP tuner, 4" MBRP, K&N intake with 6637, in tank mods
2002 7.3 EX limited 4x4, ccv mod, edge evo, 6637, RAS, In tank mods, diesel site tranny filter, JW valve body
Another method, if you have the tools (pliers and a screwdriver), is to pop off the fuel filter lid and fill the fuel bowl after putting more fuel in the tank, then start 'er up.
It'll run like crap for awhile until you get all the air out of the lines.
Stewart
__________________ The Brotherhood of FTE <-click the link 1999 F150 Lightning: WMS built block, 6lb lower, Monsterbox, Truetrac, CF driveshaft 1999 PSD F250 SC 4x4: 38R, Stage 2's, T-500, JW trans, Live Tuned, lotsa Riffraff stuff 2000 PSD Excursion 4x4: 38R, JW trans, F5, MBRP, AFE, OBA and Pre-Pump, V & B codes Never Fry Bacon NAKED!
