Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Ranger & B-Series
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series modelsSPONSORED BY:
  #1 (permalink)
Old 07-01-2012, 10:48 AM
eckart's Avatar
eckart eckart is offline
Garage is empty, add now
eckart is starting off with a positive reputation.
low fuel presure
Ive got 30 lbs of fuel presure that drops to 28 if you rev it up a bit on a 1998 ranger 4.0 with a new fuel filter. Haynes manuel say it should be 56-72 lbs. Bad news is fuel presure regulator is in the tanks with the pump. Can the regulator be swapped out or is it one assembaly with the fuel pump? is there anything i should check first? thanks Eckart
__________________
1999 F350 sd sb/sc 4X4 6spd PSD
  #2 (permalink)
Old 07-01-2012, 12:06 PM
powersmoked's Avatar
powersmoked powersmoked is offline
powersmoked is gaining momentum as a positive member of FTE.
Quote:
why are you focused on the Regulator?...... with the limited fuel pressure info you gave I can not tell if the regulator(they dont fail very often) the check valve or the sending unit is OK..........my guess is the pump itself is bad.....if you are short on cash you can just try the pump.....but most people swap out the sending unit with the fuel-pump..unless you have a lift, removing the bed is the best method.
__________________
1999 Reg Cab, Styleside, 2.5L, 2WD, M5OD, RABS, no A/C, MFG. Date 12/98, Gatorback belt, Autolite DP plugs/wires, Fluids and Maintenance done regularly, 141k as of 5/2/2012
Unless you have gone to the control panel and created a detailed signature of your truck similar to mine you are not doing all you can to solve YOUR PROBLEM!
  #3 (permalink)
Old 07-01-2012, 04:40 PM
eckart's Avatar
My son just bought it. it has a few issues. Fuel pump in it is 3 years old. the truck sat for 1 year. I think pump or regulator. I have never came across a low presure pump before they seem to either work or not. Not saying I dont think it could happen. It still has its original regulator. Seemed like something to check.
__________________
  #4 (permalink)
Old 07-01-2012, 05:16 PM
03 Maz B23 03 Maz B23 is offline
03 Maz B23 is starting off with a positive reputation.
Assume you are aware you can simply unbolt bed, remove filler neck and wiring harness and slide back bed enough to access pump in tank. No need to drop tank.
  #5 (permalink)
Old 07-01-2012, 08:56 PM
eckart's Avatar
Ya thats whats we did. very easy way to do it. Thanks
__________________
Tags
auto, car, cheap, general, insurance, powered, quotes, resources, vbulletin
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
