Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1957 - 1960 F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1957 - 1960 F100 & Larger F-Series Trucks Discuss the Box Style Ford Trucks SPONSORED BY:
  #1 (permalink)
Old 07-01-2012, 10:03 AM
Kris23 Kris23 is offline
Garage is empty, add now
Kris23 is starting off with a positive reputation.
Info help on '59 Ford F250
My father has a 1959 Ford F250. He is only the second owner of the truck and he was told that the engine is original along with the current listed mileage. He is wanting to sell the truck but is unsure of the engine size. I listed it for him on craigslist just to see if he received any interest. An individual told us that the engine is not the original as the picture we listed showed the distributor in the front but for this model and year, the only V8engine available in the '59 was a 292 Y block which has the distributor in the rear of the engine and not the front.
I just wanted to get some honest insight from people that know what they are talking about. I can get you some pics if needed to answer correctly.
Thank you
  #2 (permalink)
Old 07-01-2012, 10:24 AM
theodore/teddy's Avatar
theodore/teddy theodore/teddy is offline
theodore/teddy is starting off with a positive reputation.
Yep, Y blocks distributor is in the rear!
Of course we need pictures!
__________________
Looking for an in bed spare tire mount for styleside fridge bed.
1959 F250 4x4
Wally
  #3 (permalink)
Old 07-01-2012, 10:42 AM
Click the image to open in full size.
This is what I have of the engine. Hope it helps a little. I will be getting better ones within the next few days.
Thanks for your help.
  #4 (permalink)
Old 07-01-2012, 11:43 AM
willowbilly3 willowbilly3 is offline
willowbilly3 is gaining momentum as a positive member of FTE.
Definitely not Y block valve covers, not sure what you have by that picture.
  #5 (permalink)
Old 07-01-2012, 11:48 AM
Well, marvin looks good for his age but his not original. Got a newer engine and a 1960 hood. The radiator is newer also. I'm not the one to id the engine but if you find some numbers on the block and heads, surely some here can id it for you.
__________________
1959 F250 4x4
Wally
  #6 (permalink)
Old 07-01-2012, 11:57 AM
Buzz44's Avatar
Buzz44 Buzz44 is offline
Buzz44 is gaining momentum as a positive member of FTE.Buzz44 is gaining momentum as a positive member of FTE.
From what I can see in the pic it looks to be an FE. Could be a 352,390,360 or a few others. Without a bore and stroke you probably wont know for sure.
__________________
1965 F100 4x4 for fun. Name Gentelman Jim
1963 F250 4x4 for restore. Name Beast
1998 F150 4x4 for daily use. Name Birthday Boy
2001 Ford 4x4 Explorer Sport Trac (nice but sucks on MPG its underpowered)
Vic by the way.
  #7 (permalink)
Old 07-01-2012, 12:18 PM
52 Merc's Avatar
52 Merc 52 Merc is offline
1952 Mercury M-1
52 Merc has a great reputation on FTE.52 Merc has a great reputation on FTE.52 Merc has a great reputation on FTE.52 Merc has a great reputation on FTE.
I agree it's an FE series engine and from the valve covers I'd guess late 60's. Most likely a 390 but there's no way to tell for sure certain. The Carter/Edelbrock carburetor is not stock, either. How long has your Dad had it?
__________________
Wayne
52 Mercury M-1
among other things.
  #8 (permalink)
Old 07-01-2012, 12:42 PM
Thanks to everyone for all of your input. It is helpful!
52 MercI agree it's an FE series engine and from the valve covers I'd guess late 60's. Most likely a 390 but there's no way to tell for sure certain. The Carter/Edelbrock carburetor is not stock, either. How long has your Dad had it?
Dad has had the truck for at least 15 years that I can think of. He is only the second owner and was apprently given some false info on it as he was under the impression that it was basically all original.
When I was there visiting, we tried to look for some numbers so that I could research it some for him before listing it for sale but we were not able to find any numbers on it whatsoever.
All of your added input is extremly helpful when trying to sell it. I appreciate your help.
Thanks
Kris
  #9 (permalink)
Old 07-01-2012, 01:04 PM
99hosss 99hosss is offline
1966 Ford F-250
99hosss is starting off with a positive reputation.
Not sure about a 59 but that lightning bolt on the hood should signify a 6 cyl. motor uder the hood as original
  #10 (permalink)
Old 07-01-2012, 01:46 PM
Kris there should be a data plate on the inside of the glove box door or possibly driver side door jam. That would show year, model plus what the truck came with and should match with the vehicle identification number on the top frame rail behind the front axle in front of the cab, below the battery!
__________________
1959 F250 4x4
Wally
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
