1999 F250 7.3 Diesel will start but wont accelerate - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 07-01-2012, 01:42 AM
TheBadTruck TheBadTruck is offline
TheBadTruck is starting off with a positive reputation.
I have a 1999 F250 that will turn over and start but runs rough smilar to sucking air when it is cold outside..It lopes until I give it fuel, but then can ease off gas and it will idle ok. The RPMs will not go over 1000 when you press on the gas pedal nor does it rev up with the pedal totall depressed. The truck will not accelerate. There are no codes when it was put on a code checker. Everything else seems to be normal. It has done this once before a few weeks ago and I replaced the pedal assembly. Seemed to work and now it is doing it again.
Just replaced the fuel filter and changed the oil filter and oil but did not seem to make a difference. Also checked the turbo and looks like it is operating fine. Tried letting it sit for a while and then starting it again but it makes not difference. Called the dealer and asked if it could be the camshaft sensor and they said they didn't think so because usually if that goes bad it would just stall out. Not sure if it may be the map sensor.
Any help would be appreciated
Last edited by TheBadTruck; 07-01-2012 at 08:46 AM. Reason: Clarify how truck is starting
Old 07-01-2012, 03:13 AM
aawlberninf350's Avatar
aawlberninf350 aawlberninf350 is offline
It's a Van Gogh
aawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud of
Most code readers will not read these trucks, they are not really OBDII compliant. You'd need a fancy Snap On or AutoEnginuity or if you have an android phone get the Torque app and a bluetooth code reader off EBay. If you have no SES light don't bother.
Dealer was right (!!) with a bad CPS it will not run at all.
And I'm a bit confused: you say you need to give it fuel so it doesn't stall out, and at the same time it is completely unresponsive to the gas pedal. Can't be both.
If it smokes white that is an indication of lack of fuel, either from a bad fuel pump or blocked fuel line. Open your yellow fuel drain on the back of the fuel bowl and key it over to run, but not start. The fuel pump should run and get you a solid mess of fuel on the ground. If the volume of fuel is only marginal pull the fuel hose off the back of the pump with quick disconnects, then put some normal fuel line on the pump and into a container of fuel. If it then flows (or starts) then you know the pump is ok and your restriction is in the tank.
Could also be a Under Valve Cover Harness (UVCH, search it) came loose on ya, so you're running on 4 holes. Find the connections on the valve cover and pull one off and see if it changes things. No change means ya pulled the dead side, completely dead means ya removed the good side.
Good luck and keep trying. Lots of guys here can help.
Old 07-01-2012, 08:51 AM
Sorry aawlberninf350 I just clarified how it starts. I wrote this late last night and wasnt really clear on the starting and the accerating. I revised the post.
Old 07-01-2012, 09:50 AM
Tugly's Avatar
Tugly Tugly is offline
I'm a cautionary tale
Tugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputation
That last link in my signature may provide some help.
2004 4.6 Throttle Questions xjcamaro89 2004 - 2008 F150 19 12-20-2015 07:25 PM
1988 F150XL EFI automatic Will Not Start GormGorm 1987 - 1996 F150 & Larger F-Series Trucks 0 08-16-2015 06:44 PM
code P0122 Throttle pedal position sensor nickt916 1999 - 2003 7.3L Power Stroke Diesel 15 11-30-2013 06:15 AM
2000 F250 no power over 3000 RPM motogp310 Modular V10 (6.8l) 14 10-12-2011 08:06 AM
surging/cutting out under load accelerating 1 Ton Tommy 6.0L Power Stroke Diesel 9 09-23-2009 07:39 AM
Tags
73, california, diesel, maps, nevada, northern, powered, regional, vbulletin
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
