Nebraska's Christmas in July B/S Thread
07-01-2012, 04:09 PM
on
Quote:
Originally Posted by
GIGGER
Bman knows his High Boys thats for sure
I'm not so sure about that Gigman.. but I sure am learning!
Sparky83
the piece with the bushing still in it right behind the tire there...
Ah I gotcha, different way of mounting the cab to the frame.. Hmm.. Doesn't look to hard to fabricate though.
07-01-2012, 04:13 PM
You know more than I do man
07-01-2012, 04:15 PM
on
I've been doing TONS of research.. I like to know what I have. Just like the 92-96 f150's, I know quite a bit about them as well. Or at least I like to think so.. In actuality I don't know squat!
07-01-2012, 04:17 PM
nope sure doesnt... but just wish i knew what the frames original thickness was to make it from....
07-01-2012, 04:19 PM
on
07-01-2012, 04:23 PM
on
Hmm... gonna have to go look after work tonight now.. That doesn't look familiar at all.
07-01-2012, 04:25 PM
probably didnt pay much attention to the frame itself... might want to check it out between the bushings... frame might be just as rotten lol...
07-01-2012, 04:26 PM
on
I'll check it out when I leave work tonight. I'll let ya know what I find (with pictures if applicable).
07-01-2012, 04:28 PM
hopefully you have either a big *** breaker bar or a impact gun... the body bolts are in there pretty good with alot of tq... and thread locker...
07-01-2012, 04:29 PM
on
We have a pretty nice 1/2 inch impact. Also have the use of a friend's 3/4 inch impact. That sucker either breaks bolts loose, or breaks them off!
07-01-2012, 04:32 PM
1/2 in should do... have a good compressor??
07-01-2012, 04:34 PM
on
Oh yeah!
Tell me if that link I posted ya helps or not. I quit looking for specs when I found it.
07-01-2012, 04:44 PM
its for the newer model... but just did a quick perusal... was figuring if i did it id be using 1/8" A-36 steel... figure that should be thick enough lol.. figure if i make triangle braces to go with it - it should be good enough....
07-01-2012, 04:48 PM
on
I would think that would work pretty well. 1/8" is pretty tough stuff. Could always box it in, too.
