78 f250 front axle id
Once you get used to looking at them you can tell them apart immediately just by size. The 60 being the same basic shape, but larger in both tube size and cover size.
A good quick way to tell them apart though is that the 44 should always have used ball-joints, while the 60's of that vintage still had king-pin bearings.
So take a peek over the top of the tire and see what the pivot point is. If it's a single big castle nut with cotter pin, you have ball joints and a 44. If it's a bearing cap with 4 bolts and maybe even a Zerk fitting, it's a 60.
The steering arm on a '60 I believe should all be integrated into the king-pin bearing cap. Been awhile since I looked at mine though, so that last bit is a bit vague.
Paul
Paul
Thanks, sounds like i have a decent rig to rebuild. We used it on a cattle farm fro about 10-12 years, it was a stout rig. $00 with a 4 speed t-18. It has sat for several years. My Dad gave it to me. I plan on replacing the floorboards, replacing the bed or building a flatbed. It was parked because of the brakes. I want to slowly bring it back to life,go thru the brakes, fix a few leaks freshen up things. Once i determine the condition of the engine (pretty good when parked) i would like to put a straight up timing set and 4 barrel/ intake. I want to use it when i retire to work on the farm, some hauling pulling & wood hauling.
Warranty Plate AXLE code will not include the front axle if it only has 2 digits. If it has 3, the 3rd digit may only refer to P/S, that's why the ID tag is necessary.
