thread title says it all, my head lights will ONLY work when i pull back on the high beam lever, and i have to hold it there for it to stay on. and also my instrument cluster wont light up. turn signals work, brake lights work, so idk if the problem is with the multi function switch or if its in the steering column somewhere. any info will be great. thanks.
i have a 95 F-150 with a 5.8l. I did a search but i found no answers.
If it is the switch then a possible cause is if you added hi intensity headlight bulbs. A headlight relay harness will cure the problem. The switch has enough problems with regular headlight current draw.
i checked the white vacuum line and that looks fine. but there are two black lines coming out of the AC box and they meet at a 3way, the third line is rubber, that one is not connected. not sure where thats supposed to go.
