2 sending units on the intake manifold, help identify pls
06-29-2012, 11:36 PM
on
Is this the oil pressure sending unit (at the end of the pry bar)?
Is this the engine temp sending unit?
Thanks!
06-30-2012, 05:41 AM
The first one is oil pressure sender.
Second one is water temp for gauge.
The water temp for ecu is a dual wire plug.
06-30-2012, 05:48 AM
on
on
Oil pressure is on the drivers side front of the motor. I believe the two sensors pictured are both temp sensors ones for the computer ones for the gauge.
06-30-2012, 07:25 AM
The first one is the oil pressure switch and the second one is the gauge temp sender.
This may help:
07-03-2012, 02:04 PM
on
Quote:
Originally Posted by
subford
This may help:
Thanks a ton!
shameless
08-31-2017 09:58 AM
FORDF250HDXLT
45
03-23-2013 02:40 PM
1975StroppeBaja
1999 to 2016 Super Duty
11-11-2008 01:22 PM
tomtoc
11-19-2007 12:38 AM
Pompanosix
Electrical Systems/Wiring
06-21-2006 08:03 PM
