Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Western Region > Oregon Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Oregon Chapter Join Chapter, Leader: Fabmandelux
  #1 (permalink)
Old 06-29-2012, 10:01 PM
WarOzz's Avatar
WarOzz WarOzz is offline
1992 Ford F-250
My Garage
WarOzz is gaining momentum as a positive member of FTE.
just saying hi
Hey all, just stopped by to ask the diesel truck guys a question about my truck.. thought I would post it here as well and say hi since I haven't been around much lately. I am still getting used to the new job and living at the coast. Someday life will slow down and I will visit more.
Any of you guys know how to get the clutch master cylinder push rod off the master cylinder?
Mine needs a little machine work and must be removed
__________________
Ed - Lincoln City, Oregon - Oregon Chapter Member | Join Our Chapter Here
Machinist/Programmer - Jim Meyer Racing Products
1992 F250 S-Cab 4wd 7.3L IDI ZF5 - Straight Pipe, Ram Air, IP Turned Up, Bi-Xenon 6k HID Lights in Clear Euro Lenses.
1975 F250 Camper Special - Soon To Be Transformed!
  #2 (permalink)
Old 06-29-2012, 11:45 PM
892504x4's Avatar
892504x4 892504x4 is offline
Garage is empty, add now
892504x4 has a good reputation on FTE.892504x4 has a good reputation on FTE.
And a hello back, understand that life can get in the way of a lot of things. Living on the coast is a hole other thing especially in the summer ( if we get one ) with tourist and all the brain dead vacationers.
__________________
Chris 1989 F-250 Super Cab 4x4 5.8L 5 speed now calling Frankenstein
"There are only two ways to live your life.
One is as though nothing is a miracle.
The other is as if everything is. "
~ Albert Einstein~
  #3 (permalink)
Old 07-09-2012, 12:20 AM
Brown Falcon's Avatar
Brown Falcon Brown Falcon is offline
1995 Ford F-350
Brown Falcon has a great reputation on FTE.Brown Falcon has a great reputation on FTE.Brown Falcon has a great reputation on FTE.Brown Falcon has a great reputation on FTE.Brown Falcon has a great reputation on FTE.Brown Falcon has a great reputation on FTE.
Hey, nice to hear from you. Can't help you with the clutch problem...
__________________
Brownie (Evan) Ooh-Rah! Once a Marine Always a Marine Oregon Chapter Member
'95 F350 CC 4x4 - 7.3 PSD, 190k, Built E4OD, SRW Conv, 4x4 Conv, Rosewood Stage I's, PHP Chip, 6637 Intake, 3" DP, Lost Kitty, 4" Exhaust, 3" RSK, 38 gal rear tank, fuel vent mod, 140v IDM, HPX, FPR Shim, 3.55 gears
'10 Escape, 200hp 3.0 V6, 4x4 - Stock
  #4 (permalink)
Old 07-13-2012, 11:51 AM
Seabiscuit-P3's Avatar
Seabiscuit-P3 Seabiscuit-P3 is offline
Seabiscuit-P3 has much to be proud ofSeabiscuit-P3 has much to be proud ofSeabiscuit-P3 has much to be proud ofSeabiscuit-P3 has much to be proud ofSeabiscuit-P3 has much to be proud ofSeabiscuit-P3 has much to be proud ofSeabiscuit-P3 has much to be proud ofSeabiscuit-P3 has much to be proud ofSeabiscuit-P3 has much to be proud ofSeabiscuit-P3 has much to be proud of
Hi Ed. Been on a trip and I'm still catching up on all the posts since I took off. Good to hear you are still here.
My PSD is an automatic so I'm not sure any of the following applies.
If it is anything like the 460 F250 I had you have to start under the dash. There is a plate there over the top of the pedals, and the pedal rod connects to the cylander rod on the left (laying on your back looking up). Check this "pedal plate" as I had two of them crack on me. Have to pull a speed nut off of the end where the rod from the pedal connects to the rod from the cylander. From there, IIRC, we pulled the clutch master cylander from the firewall and everything just kind of pulled apart from there. At the suggestion of a fleet mechanic, we welded a small metal plate on the firewall to make it more rigid and the mounted the cylander back on top of this plate. Made things more firm and I had fewer clutch problems after that and no more cracked plates.
Anyway, if any of this sounds or looks familiar, I may still have some instructions or pics from a book around here someplace that I'll try and find for you.
__________________
Jim - 1996 F250 PSD SuperCab 4X4, Fender Flares, Auto Hubs, E4OD, C5 4.10 limited slip, Carr Hoop II steps, Warn XD9000i Winch & Trans4mer brush guard. Pretty much stock.
To join the Oregon Chapter, click HERE
There cannot be a crisis next week, my schedule is already full! (Henry Kissinger)
In the first place God made idiots. That was just for practice. Then he made Congress. (Mark Twain, slightly modified)
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
