300 I6 with a C6 Question
I'm pulling out the 351w and putting in a 300 in my 89 F250. I know I will need a new radiator but I noticed that the lines for the oil cooler on the 351 are on the opposite side of the radiator from a radiator for the 300. Is there a conversion kit for this? How do I get the lones over to the opposite side?
I'm not sure I made that clear.
On the v/8, the top hose Fill, and trans lines are on the passenger side. water pump line is on the driver side.
On the I 6, the Top hose, fill, and coolant lines are on the driver's side, Wayerpump draws from the passenger side.
Return lines from the trans cross over under the core support
Maybe this is where I am getting confused. The one I pulled out of the truck has top fill, passanger side, but the trans line was at the bottom on the drivers side just above the bottom hose. It is a pre-bent line that hooked in for the trans. I will try to take a pic of it and post when I get home this evening.
greentruck72
09-12-2017 06:30 PM
dennisg_70
08-29-2005 01:39 PM
