You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
I'm pulling out the 351w and putting in a 300 in my 89 F250. I know I will need a new radiator but I noticed that the lines for the oil cooler on the 351 are on the opposite side of the radiator from a radiator for the 300. Is there a conversion kit for this? How do I get the lones over to the opposite side?
__________________
Rick Kerfoot
89-F250 Project truck
The Radiator for the I6 is reversed frpm the v/8/ cooling lines go on the side the return coolant line is on.
__________________
Charlie slackmaster #26 "A common mistake people make when trying to design something completely fool proof, is to underestimate the ingenuity of a complete fool."
"If more sane people were armed, the crazy people would get off fewer shots."
"Some people are alive because it's illegal to shoot them"
On the v/8, the top hose Fill, and trans lines are on the passenger side. water pump line is on the driver side.
On the I 6, the Top hose, fill, and coolant lines are on the driver's side, Wayerpump draws from the passenger side.
Return lines from the trans cross over under the core support
__________________
Maybe this is where I am getting confused. The one I pulled out of the truck has top fill, passanger side, but the trans line was at the bottom on the drivers side just above the bottom hose. It is a pre-bent line that hooked in for the trans. I will try to take a pic of it and post when I get home this evening.
__________________
Rick Kerfoot
Here are the 2 lines I was talking about that are on the drivers side.
I did notice that the line for the trans oil was apparently cut and redone with a piece of hose and clamps. Possibly cut and redone to match the radiator???
__________________
Rick Kerfoot
You will have to cut the lines, make a 90* turn, run accrossed the core support, and hook the lines to the other side.
As for the patch in the line, probably you had an oil cooler in there that someone cut out/
__________________
No problem. My radiator is out of the 82, I was going to take a picture next, to show It's a mirror image.
Too bad that radiator won't work for you. Different core support, different mount.
__________________
It's the f 350 with electric fan and 3g alternator conversion, but you'll get the idea
It has a manual transmission, but you can see the trans fitting if you look below the radiator cap
__________________
