Go Back   Ford Truck Enthusiasts Forums > Marketplace > Vehicles for Sale
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Vehicles for Sale All vehicles (Ford Truck or otherwise) for sale here
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Location (State):
Parts Search
Keyword:
Category:
Price:
Private or Vendor Listing:
Location (State):
Item Condition:
Closed Thread
  #1 (permalink)
Old 06-29-2012, 03:14 AM
breckman99 breckman99 is offline
1990 Ford F-250
My Garage
breckman99 is starting off with a positive reputation.
12V P7100 Swapped OBS Crewcab 4x4
Year: 1996
Make: Ford
Model: F-350
Price: $7000
Mileage: 200000
Color: Silver
Private or Dealer Listing: Private Listing
Location (State): CO
Transmission: Manual
Drivetrain: 4WD & AWD
Color: White
Engine: 5.9L Cummins 12V P7100
Well folks, after much deliberation, and against my wife's opinion, I've decided to sell this project. It runs and drives, in fact has been my DD for the last 90K miles. It does need a few things to make it 'perfect':
Radiator
Throttle assembly and shutoff solenoid ( currently pull handle shutdown and ford throttle)
Has 4.10 gears, max speed is around 65 (have full set of 3.54/3.55, included)
Speaker blown in drivers door
ZF5-42 has around 350K on it, still shifts great. Have extra ZF547 with a broken bell housing I'll throw in
Exhaust is rubbing somewhere when turning sharp corners, needs adjustment
Front driveshaft pinion seal leaking on transfer case
Ball joints and alignment
Tires
Small dent in the passenger rear door
High pressure PS line leaking
AC lines need to be made and installed, as well as AC pump wired in(brand new pump)
Other than the above, the truck is incredible. The Cummins came from a 96, freshened it up with a brand new injection pump from Bosch and head gasket for good measure. Kept all power STOCK levels @ 215 HP. Drive shafts are standard length, everything is original but the engine and radiator support. PO added running boards and a visor, which has peeling clear coat but the remainder of the body is great. When the engine was installed, Dynomat was applied to the undercarriage and all frame was repainted, peeling in some places.
Transmission is the ZF542 with a destroked plate, 6.0L gear reduction starter, 3.5" downpipe to 4" stainless fully welded exhaust with high flow muffler, stock transfer case, and no further modification to any of the remainder of the truck. In fact, I kept the original matching radiator support in case someone would one day want to return the truck to stock from. Interior is a 7/10, with 3 burn marks on the seats and a few burn marks in the carpet. PO mounted a CB on the roof, mount is still there. Original radio works with the exception of the drivers door speaker.
Comes with a 10K lb hitch and extra set of matching wheels. Considering how much money I have dumped into this thing, I feel retarded selling it but I have no time to fix the little problems on her. Time to get a reliable 'city' car and I'll build another ford when I retire.
Mileage on engine is 120K. Mileage on body is ~208K, increasing by the day until she sells.
Pics:
Click the image to open in full size.
Check out my garage for build pics etc. If you have any city cars I may be interested in a trade, but must have AC and ready to drive my *** to work every day without needing major work for the next few years. Don't waste my time looking for payment plans, joyrides, or any of the usual shenanigans.
Closed Thread
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
