Drivetrain Slack Clunking
I agree with Andrew. Did you drop the pan for a look? Or has the dealer done so? Might be worth taking it to a reputable trans shop for another opinion. Somethings not right. You can start to build a story line by obtaining other professional opinions about what the cause is and that might give you more fighting power with Ford? Go to another dealership or three?
If you take your front drive shaft off and look down in it , there is a round metal plate that should be blocking your view. If you do not see it, that is the problem. the plate has came loose and is banging back and fourth inside the driveshaft. I have read ever other soultion to the banging,clanking.clunking noise or what ever you want to call it but this is what my problem was. After cleaning the inside of the driveshatf and letting the plate slide down to the end , I put JB weld on it. Problem gone. Hope this help someone.
I know this is reviving an old thread, and I hope this is acceptable on this forum, but this was VERY helpful information and I am going to attempt this slip joint regrease prob for no other reason than its never been done, I am sure.
Now, my question is I am having this same issue on my 4wd LOW only as I have a ZF 5 spd manual. Anyone else?
06 E350 box truck
My 07 E350 box truck (5.4) does the exact same thing. I bought it new with 30 miles on it and now has 58,500 on it. I took it to 3 ford dealers and they couldn't find anything wrong with it. Mine "clunks" at about 15 mph and once I come to a stop again it "clunks" and will actually push the truck foreward a few inches. I would bring it back to the dealer if still under warranty and tell them what it's doing and show them if possible. My truck Is now out of warranty from ford but this un-resolved rear end issue Is the reasion I got an aftermarket warranty. Keep us posted as I'm interested to know how this turns out. Good luck!
