Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 06-28-2012, 07:00 PM
Boss9F100's Avatar
Boss9F100 Boss9F100 is offline
Garage is empty, add now
Boss9F100 has a good reputation on FTE.Boss9F100 has a good reputation on FTE.Boss9F100 has a good reputation on FTE.
Ford Tech Help Needed '07 Expedition Multiple codes
2007 Expedition 70k miles. Friend purchased from dealer and before veh made 2 miles the wrench on dash came on, check engine light, it went into limp mode.
I cleared codes and it was good for about 2wks. multiple codes now
Veh cuts out, gauges go all over and read wrong, speedo quits, goes into limp mode. Shut veh off and it did not want to restart. Cleared codes and it started but went into limp mode, seems like all modules, computers and dash are losing power intermittently.
I am curious if someone has ran into this issue. Seems to me its a loose or partially broken wire or possible computer itself. In all my years of messin' with fords I have changed ZERO Computers.
Partial List of Codes
P1500
P1000 KNOW THAT ONE
U0155
U0101
U0100
B2916
B2917
U0121
U0151
U2199
U2023
U2471
B2293
U1900
I think its all pretty much related because of a power loss of sorts...
Just so it is clear I can look up codes but wondering if others have seen same issue with so many multiple codes that seem related to power failure.
__________________
1966 F250 Deluxe Camper Special "RANGER" Special Paint
1965 F250 Deluxe Camper Special Unrestored Original
1966 F100 powered by a 482" Dual Quad Side Oiler
1966 F100 Plain Jane AZ Grandpa Truck 352 3spd
1966 F250 Plain Jane Red/Red Long Bed 3.5L EcoBoost
02' PowerSmoke
  #2 (permalink)
Old 07-24-2012, 08:23 PM
Boss9F100's Avatar
07 Codes
Anyone with ideas? A month later and still not fixed . . .
So far all connectors have been taken apart and pins inspected, all grounds inspected & cleaned, inspected wiring harness but of course did not remove.
The IC
ABS
Trans
and all other modules lose power at approx the same time.
1st thing noticed is the power to test port so any diagnostic device loses power then the speedo starts bouncing the wrench light comes on, abs light, check engine, trans will no longer shift and the engine goes into limp mode, the A/C system shuts down.
It only does it when things are warm/hot never cold. Runs absolutely perfect until this happens. Even the fuel mileage is incredible... until things go south.
Yes, The PCM has been replaced. Unable to do a computer module software upgrade because with this model it cannot be done until it has completed a full drive cycle. It has never completed a full drive cycle. 6 of the 7 parameters only. Mostly because it takes that much longer here when the ambient temp into engine is over 100.4 deg f
__________________
02' PowerSmoke
  #3 (permalink)
Old 07-27-2012, 11:27 AM
function12's Avatar
function12 function12 is offline
function12 is starting off with a positive reputation.
Sounds like a short in a wring harness somewhere.
__________________
See ya,
Eric
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
