Soft brake pedal, firm on second pump. What's wrong?
I have spongy brakes on my '08 EL using about half of pedal travel. The second pump uses about 1/4 travel. My mechanic tried to bleed the brakes of any air but it didn't help. There is no leaking brake fluid. I'd like to get sorted out before heavy towing.
Anyone have an idea if this has to still be air in brake lines, master cylinder seal issue or something else?
Soft brakes
I agree it would appear I have air in the system. However, I would think that air in the system would be soft on the second pump, not firm like I am feeling.
Agree?
For the alternate theory that "some of the Expy/F150 just have mushy brakes: I have a hard time believing a 1 million unit per year platform has brakes that cannot be made to work consistently.
I hate to say it, but it would seem to me that this is a bad master cylinder seal that doesn't push against the cylinder wall until extra pressure from a first pump pushes it to seal. Does this make sense based on the design of the master cylinder seals (no idea what they really look like)?
Agree?
Now if....you hold your foot on the pedal and with the engine running is slowly drops, then you have a master cylinder issue.
I remember my dad had a chev back in the early 60's, he worked for hours bleeding the brakes and could not get the "bubble" out, ended up taking to a brake shop, took them 3 days bleeding with a pressure bleeder in different methods befor finally getting the air out.
I have the same problem on my 07 expy and also had the same problem on my 07 sport trac that I got rid of. the sport trac I bought new and I had it back to the dealer 5 or 6 times they bled the brakes, replaced the front calipers, replaced the booster and master cyl, and did a tsb on the brake pedal, nothing helped. finally at 24k miles the rear brakes were worn down and I was about out of time on the warranty so I traded it in, but I thing that it might be something in the brake bias in the ABS unit. I think that we are stuck with the problem. I just bled the brakes on my expy and i dont think that it helped.
I have been living with this soft pedal issue ever since I bought the Navigator new in 2007. Has anyone come up with a fix or aftermarket solution.
I have no idea why these were designed to be so soft with no easy way to adjust. There is a thread in the F150 forum that shows the brake booster rod being adjusted, solving the issue but apparently the rod has been redesigned.
My 08 Expy does the same thing...What I believe the problem we are having is in our"Sealed wheel bearing assemblies"...I'm thinking that as the wheel rotates with the brakes not applied,lateral or any excessive runout with the rotor,causes the piston(s) to be pushed in slightly to move the pads away from the rotor surface,then upon the second application,the pads are closer to the rotor(s) surface causing a firmer pedal...If you have ever had a conventional tapered bearing fail or be out of adjustment,you get the same effect....Practically every sealed bearing I've ever "wiggled" on the car has some amount of play...Believe me,this condition can be drastically worsened towing a 27ft travel trailer,(especially in high wind conditions)...just my 2 cents.
degdawgs
10-15-2005 10:00 PM
