Air Ride Suspension - Page 9 - Ford Truck Enthusiasts Forums
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Air Ride Suspension
  #121
Old 04-27-2010, 02:50 PM
seventyseven250's Avatar
seventyseven250 seventyseven250 is online now
seventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud of
With 120 responses, even if the OP is long gone, there are plenty of people who are interested in this topic who are still around. Also, if a new thread is started, then you have to re-post any helpful info from the original thread, or it'll get missed out on by the new poster.
Old threads rule!
  #122
Old 04-28-2010, 06:11 PM
illgorhythm illgorhythm is offline
illgorhythm is starting off with a positive reputation.
Yes! Now Im a part of a 7 year old thread!!! w00t!!!
  #123
Old 04-28-2010, 07:35 PM
Moto Mel's Avatar
Moto Mel Moto Mel is offline
Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.
Threads this long and old should be archived under a descriptive term so everyone can find it. There should also be an age limit on any thread of say, 6 months and then archive it. Some threads are so old that the main subject gets skewed into another topic and to figure out what is being said and it's relationship with the rest of the thread you have to read through the whole thing.
Administrators, are you listening?
  #124
Old 07-01-2010, 09:21 PM
jburdslim jburdslim is offline
jburdslim is starting off with a positive reputation.
So I've been reading through this thread for a couple of hours. My '99 EB's rear suspension is shot! Went out of town, left it parked in the driveway...sitting on the wheels when I returned. Figured out the pump was shot...it actually came on...sputtered for a few seconds and died... We replaced it with a new one from Arnott, Inc. Jumped directly from the battery to test the new one and the old one. New one works, old one is shot (confirmed). Plugged it back up...nothing. Disconnected the battery for 5-10 minutes, reconnected it...nothing. Any helpful hints out there. I'm sure this has been addressed in this post somewhere...I'm just missing it. HELP....MY BACK IS KILLING ME NOW...AND I THINK I MIGHT HAVE WHIPLASH!
  #125
Old 04-26-2012, 12:20 PM
austinmd austinmd is offline
austinmd is starting off with a positive reputation.
Angry air ride suspension help please
I have a 1999 Ford Expedition with 4 wheel air ride suspension and the rear suspension is completely flat and I have taken it to two garages and paid the $70.00 each to tell me what was wrong and so it appears they just want to throw parts at it because I replaced the compressor and drier per first garage then the rear flow sensor per the second place. so front air shocks are a year old and rear air bags are a few years old per previous owner so all that is left to replace is two more flow sensors, air lines and the relay. I am seeing things in this thread about a relay and a air suspension electrical variable orifice (evo) out of range where are these located and are there ways to test them.
rear ride height sensor is attached and when I move it the compressor does kick on.
I do know all about how you can replace the air ride with struts so please don't post letting me know about this option I am going to beat this thing and then when I go to the garages to get my money back I can tell them what was wrong since they couldn't figure it out.
  #126
Old 05-12-2012, 08:03 PM
lford78 lford78 is offline
lford78 is starting off with a positive reputation.
Need Shocks, How do I know if I have an Air Ride Suspension
I currently have an 1998 Expedition XLT 4x4... I was wondering if anyone knew what I should look for to identify if I had an Air Ride Suspension... I am not sure if I do now after replacing the tires and looking at it. Is there any tell tale parts that would say absolutely for sure if I had one?
I originally thought I might have had one because I saw a large canister (looked like an air tank) in the back corner of the my Expedition, behind the rear tires. I thought this might be a tank for the air-ride but when I went and had the brakes and tires replaced I did not see any air-bags in the back and the shocks in the front looked like regular shocks.
A friend of mine said the tank in the back might be for the A/C because of the rear climate controls... I am at a loss as to what I need to purchase to fix my suspension. Any help would be appreciated
  #127
Old 05-12-2012, 08:55 PM
pdqford pdqford is offline
pdqford has a good reputation on FTE.pdqford has a good reputation on FTE.
Bingo! No LLS (Load Leveling System).
  #128
Old 05-31-2014, 12:02 PM
Stlakid Stlakid is offline
Stlakid is starting off with a positive reputation.
2008 expedition
Quote:
Originally Posted by averygenosi View Post
Hi Guys!
Being a self proclaimed Air Bag Specialists (due to lifting my truck and taking apart the air bag assembly), the airbags can be adjusted easily by crawling underneath the back of the truck. The sensor is connected to the middle of the track bar (not the rear diff as was noted earlier). The senser is vertical and connects to the undercarriage. By taking two 14mm wrenches (I think it is a 14) you can adjust the sensor on the track bar all the way to the top and 'trick' the truck into thinking it is loaded, therefore inflating itself to a higher level. Do not worry about over inflating the airbags because the adjustment range is not large enough to put the airbags in any kind of danger. E-mail me and I will send you the appropriate pictures if you are curious. If the height that you are looking for is not acheived by this then let me know, as I have an Extra Fabtech rear lift for the Air bags that will give it the height you will desire. I know the forum is not for selling but I am just trying to help you out.
BTW. The only way to reset the compressor is to disconnect the battery for 6-7 minutes.
Hey can I get your email and does this work on the 08 expeditions as well?
  #129
Old 06-20-2014, 05:09 PM
iRocco iRocco is offline
iRocco is starting off with a positive reputation.
Hello BigMattXXL
...As it rests on the bump stops you have no suspension and the truck rides like crap. Every time you hit a bump it hurts...
I went up from Crystal Lake, IL to Ironwood MI this winter for a weekend of snowmobiling. The compressor failed on the way home. 6 hours of driving with the back end bouncing wildly with every ripple in the road was torture. The kids in the back seat had to lean over so their heads wouldn't bash into the roof. Holy Moses, it was a rough ride. But by the end, we were all laughing uncontrollably at the absurdity of how much bounce each small bump produced. I thought for sure the bags would be trashed and was thinking the whole truck would just break apart. But the bags are fine, and so far the frame is still holding together.
  #130
Old 06-20-2014, 05:17 PM
This thread is still newer than my truck...!
Quote:
Originally Posted by Moto Mel View Post
This thread is 7 years old, lets let it rest in peace.
My truck is 17 years old. Old does not mean useless. If you don't like old threads, my thought is, don't read them.
  #131
Old 06-20-2014, 08:57 PM
alloro alloro is offline
alloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to behold
Quote:
That's right, I can think of plenty of ways to still ride something that is 17 years old.
  #132
Old 11-19-2014, 01:33 PM
cedavis cedavis is offline
cedavis is starting off with a positive reputation.
Can I have some help please?
I have a 2005 Lincoln Navigator. I feel I have a sensor or control module problem with my air suspension. Every time you turn it off it lets air out of the front - and it is supposed to - but it lets way too much out I feel in the front. The wheels typically touch the wheel well. So after you turn on the vehicle the pump has to work extra hard to fill the bags with air. I also feel it takes its time to work its way to having the front height at the proper level.
There is no leak and the pump works fine. You can hear the solenoids clicking when the valves are opened and closed and both left and right work in usison. There never seems to be a problem in the rear suspension.
Is this a sensor problem? The front is always level so I doubt both sensors are gone in the same manner. Is this a control module problem? Does the system simply need calibration? Is only a dealer equipped to calibrate?
Thanks.
Cary
  #133
Old 11-19-2014, 04:21 PM
Quote:
Take a measurement from a point on the front of the truck to the ground, both with it deflated and again after it's pumped all the way up. What are the two measurements?
  #134
Old 11-20-2014, 12:38 AM
Quote:
When the system is running normal, the height from the ground to the top of the fender is 34.5 inches on both sides. After turning off the vehicle it goes to 33.5 inches on both sides. That seems normal.
This problem seems intermittent. When the suspension fails it will let air out to the point that the fender to ground height goes down to 31 inches on the driver's sider and 30.5 on the passenger.
Seriously, when the system fails, as an example, I can sit at a red light and the system lets the air out - while the pump is running and then pump it all back up again. Tonight I got into the vehicle and it was working fine and the heights were good. Once I began driving it let all the air out to the very low values I quoted above driving flat on no suspension and the wheels rubbing the wheel well. - Yet an hour earlier it was working as designed.
  #135
Old 11-20-2014, 04:04 PM
Yes that's normal and if you switch into 4WDL it will go up an additional inch or so. It does that because it assumes you're going off road and could use a bit more ground clearance.
As to the dropping down to the frame, based on your last description it sounds like the air release solenoid is intermittently leaking.
Does a crown vic suspension lower the ride height? Turbo Dog 1967 - 1972 F-100 & Larger F-Series Trucks 24 12-19-2016 05:01 PM
Rear suspension help? Last Triumph 1948 - 1956 F1, F100 & Larger F-Series Trucks 1 08-30-2015 10:07 AM
2004 Navigator - new height sensor, won't inflate talltorontoguy 1997-2006 Expedition & Navigator 5 06-24-2015 11:06 PM
how to adjust volare front suspension ride height 0to100to0 1948 - 1956 F1, F100 & Larger F-Series Trucks 21 08-18-2014 10:39 PM
air suspension stvebro 1997-2006 Expedition & Navigator 3 01-30-2003 09:49 AM
Tags
air, california, expedition, ford, hite, lifted, relay, reset, reseting, ride, sensor, shop, suspension, system, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
