'84 f150 carb tag
Old 07-25-2012, 07:07 PM
broncoguy48's Avatar
broncoguy48
broncoguy48 is offline
'84 f150 carb tag
Hi all,
My '84 f150 4.9L six is in need of a carb kit and some other carb parts. The problem is, someone has been in there before me, and removed the carb ID tag and didn't put it back! Is there a way to determine the numbers that were on the tag from the VIN or other information? It is an electronic feedback 1 bbl that looks to be a Carter.
Old 07-25-2012, 07:28 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
81-F-150-Explorer is offline
Without the tag, you will have to use the Carter and/or Weber stamping number.
You should be able to find the number stamped to the lip of throttle body on the driver side of the carb, right where it bolts to the intake.
It will have a four digit number and/or with a letter, something like 7329 or 7843S.
Post that number and I'll see what I can find.
Old 07-25-2012, 07:34 PM
Grubbworm's Avatar
Grubbworm
Grubbworm is offline
First off, let me welcome you to the forum.
Someone will come along with more information soon.
I should also ask if you could post some pictures so we can better identify your issue.
But first, let me ask you a couple of questions, so that we can narrow it down a little further.
Does your carburetor look like this;
And do you have a gray module on your distributor like this one does;
Old 07-25-2012, 11:32 PM
broncoguy48
Thanks for the quick response! The number you pointed me to is 7596S.
Old 07-25-2012, 11:38 PM
broncoguy48
My carb is just like that one, and the TFI module is gray. Thanks for the quick response!
Old 07-26-2012, 01:43 PM
81-F-150-Explorer
Original Carb tag number is E4TE-FA.
I found you a few kits... The Motorcraft kit is obsolete...
Borg/Warner: BWD: Part #: 10712B
Walker: Part #: 15789C
Napa: Part #: MPF 31220C
Old 07-26-2012, 08:43 PM
ctubutis's Avatar
ctubutis
ctubutis is offline
Gosh, you're good.
Old 07-26-2012, 11:59 PM
broncoguy48
Thank you so much! I have been trying to find this information since I overhauled the engine 20,000 miles ago! I put a kit in at that time that was a guess, and it was close but not the right one. The truck runs well, but never had the power it should after a .040 overbore rebuild. Thanks again! I owe you one!
Old 07-27-2012, 09:47 AM
1986F150six's Avatar
1986F150six
1986F150six is offline
Felcome to the forum, broncoguy48!
See that red heart to the right of the posts? That will give a "rep" to the one who helped you.
Old 07-27-2012, 10:03 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Carb ID tag number: E4TE-FA = Ford part number: E4TZ-9510-F .. Carter 1V Carburetor (Motorcraft CA-3291) / Obsolete
E5PZ-9A586-E .. Carburetor Kit (Motorcraft CT-1302-C) / Obsolete
Closest sources with carb kit to OP's IL residencia:
EVANS FORD in Carrollton IL has 1 = 217-942-3636.
GREEN SALES CO. in Cincinnati OH has 4 = 800-543-4959.
VINTAGE PARTS INC. in Beaver Dam WI has 7 = 877-846-8243.
Old 07-27-2012, 10:07 AM
1986F150six
Thanks, NumberDummy, for your continued willingness to take the time to share your knowledge!
Old 07-27-2012, 10:23 AM
NumberDummy
Originally Posted by 1986F150six
Welcome to the forum, broncoguy48!
Reps (good or bad) do not count (they're neutral) until the member reaches 25 posts.
Many members are unaware of what reps are, or how to give them. I'm aware, so you received a few from me.
Old 07-27-2012, 12:49 PM
81-F-150-Explorer
Speaking of NOS (New Old Stock) carburetor kits...
I wonder if they would stand up to the Ethanol Gasoline that they make us burn now?
Old 07-27-2012, 12:55 PM
NumberDummy
Us? I have never seen ethanol at any gas station here in SoCal.
When one drives the oversized tub that I do...that...so far has averaged 14.8 MPG overall (according to the onboard computer), one stops at a lotta gas stations.
My three previous 2004/2005/2006 NotaFord and 2004 F150 Lariat Stupor Crew pickups got about the same MPG as the current oversized tub.
Didn't have to stop as much w/the 2008 conFusion 4 banger (traded it in on current oversized tub), as it got better MPG.
I usually don't bother checking MPG, because who in their right mind would buy a full sized pickup and then expect to get decent MPG?
The only times I've bothered over the past 50 years: Gassed up the 2006 Titan, then drove to San Diego and back, filled it up when I returned: 18.6 MPG. This had to do w/a poll on titantalk.com
Was curious inre to the 2008 conFusion, did the same thing, same San Diego trip: 33 MPG. Ditsy MIL lives there.
Old 07-27-2012, 02:08 PM
broncoguy48
Carb ID tag number: E4TF-FA = Ford part number: E4TZ-9510-F .. Carter 1V Carburetor (Motorcraft CA-3291) / Obsolete
Thanks much for the info NumberDummy! Is the tag ID E4TF-FA, or E4TE-FA?
Quick Reply: '84 f150 carb tag
