A sub volume control question - Ford Truck Enthusiasts Forums
2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Old 06-28-2012, 02:26 PM
Crash80's Avatar
Crash80 Crash80 is offline
Crash80 is starting off with a positive reputation.
I did a search but did not find an answer to my question. I bought an 08 Expy EB with the 6 disc changer, 7 speaker set up. Am I correct in that you cannot control the level of the subwoofer? I came out of an 08 Honda Element SC with a slammin little factoy stereo set up that allowed control over bass and treble as well as how much sub you wanted to dial in...I am not seeing that option on this Ford. Being a pro audio guy, this bums me out to no end.
Old 06-28-2012, 08:28 PM
mtondreo mtondreo is offline
mtondreo is gaining momentum as a positive member of FTE.
you are correct that there is no separate control for it. However, if you install an aftermarket deck with sub control - it will control it. The wire kit converts it to rca's at the deck.
Old 06-29-2012, 09:03 AM
Crash80's Avatar
Quote:
Thanks for the info. Do you know if the factory nav unit would allow for the sub control I am after, or is aftermarket my only option?
Old 06-29-2012, 06:41 PM
RI-Matt's Avatar
RI-Matt RI-Matt is offline
RI-Matt is starting off with a positive reputation.
Quote:
Factory NAV only has bass and treble controls like the basic radio. It does have the DSP (digital sound processor) option to adjust for drivers seat, all seats, and rear seat positions. Not sure if the basic radio has that option.
Matt
Old 07-02-2012, 09:47 AM
Crash80's Avatar
Thanks for all the help fellas.
Old 07-06-2012, 09:26 PM
CarbonClear CarbonClear is offline
CarbonClear is starting off with a positive reputation.
Theres another option you can consider. It will add more cost, but its just my 02.
I felt that the subwoofer that came from factory was not enough. My truck came with the factory navigation and wanted to keep the factory look as much possible due to my work surroundings. So I removed the factory subwoofer to allow room to mount a amp. I added a 10 inch subwoofer in the rear with a sub base remote. The sub base remote was mounted on the front fascia under the nav. I used that setup for over a year, until I got the mod bug again and happen to come across a good deal on a aftermarket nav unit and replaced the factory nav. Either way you can't go wrong and good luck
Old 07-09-2012, 08:32 AM
Crash80's Avatar
Thanks. I have been researching some sort of aftermarket sub volume control unit and that is probably the route I will take with this Expy.
Old 07-09-2012, 07:28 PM
eddiemoney eddiemoney is offline
eddiemoney is starting off with a positive reputation.
The factory sub won't really react much different with any sort of control, you really need to replace it. If i recall, when i took the sub out to look at it, it was very shallow mount (2ish inches) and a 1.7 ohm DVC...almost impossible to replace. You are better off either a) mounting an amp under the seat and building a custom sub enclosure in the existing place or b) amp in the sub location and a sub somewhere else (maybe just a box sitting in the back.
Old 07-10-2012, 09:28 AM
Crash80's Avatar
Quote:
I can appreciate that. Even if I went this route, I would still want to have seperate sub volume control. I am not the type of guy that likes a license plate rattle low end experience but I still like being able to dial in how much boom I get. Having the bass level and sub level locked together is just plain idiotic in my books. I appreciate your comments and will keep your comments in mind when I get around to this project. Right now I am just dumping gas into this thing at a rate of mind boggling.
Old 07-11-2012, 09:30 PM
Every 3-4 days for me
Aftermarket HU in 2002 Escape question about sub circuit... WB4IUY Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 6 08-20-2016 07:59 PM
08 Expedition EB subwoofer control Crash80 Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 0 07-16-2012 11:33 AM
Q logic subwoofer box. DieselBeast01 2004 - 2008 F150 12 11-03-2011 11:16 PM
looking to upgrade adt7108 Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 6 08-24-2007 01:35 PM
Help me choose an amp for my sub! Munkey Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 4 02-19-2004 04:52 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
