socket size for lug nut - Ford Truck Enthusiasts Forums
Old 06-28-2012, 11:21 AM
macguy macguy is offline
macguy is starting off with a positive reputation.
what is socket size for lugnut on F250 6.7? I want to torque my wheels with 1/2 drive, but need socket size to buy.
Old 06-28-2012, 12:20 PM
jlalanas's Avatar
jlalanas jlalanas is offline
jlalanas is gaining momentum as a positive member of FTE.
I think it's 13/16 or 15/16, can't remember exactly.
Old 06-28-2012, 12:55 PM
PITS's Avatar
PITS PITS is offline
PITS is gaining momentum as a positive member of FTE.PITS is gaining momentum as a positive member of FTE.
You can use a 13/16"
Old 06-28-2012, 01:22 PM
720Deere's Avatar
720Deere 720Deere is offline
720Deere has a brilliant future720Deere has a brilliant future720Deere has a brilliant future720Deere has a brilliant future720Deere has a brilliant future720Deere has a brilliant future720Deere has a brilliant future720Deere has a brilliant future720Deere has a brilliant future720Deere has a brilliant future720Deere has a brilliant future
Actually it is none of the above. You guys need to accept that 90% of the hardware on these trucks is metric including the lug nuts!
Old 06-28-2012, 01:24 PM
SavageNFS's Avatar
SavageNFS SavageNFS is offline
not a WHITE truck
SavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputation
Quote:
I don't have stock tires, so I don't know the size. However, why make this statement and not provide the correct size then?
Old 06-28-2012, 02:04 PM
jlalanas's Avatar
Think it might be 22mm, but 13/16ths works just as good.
Old 06-28-2012, 02:17 PM
PITS's Avatar
Technically it's a 21mm. A sloppy 13/16" will work just fine.
Old 06-28-2012, 07:04 PM
TRENT310's Avatar
TRENT310 TRENT310 is offline
TRENT310 has a spectacular reputation.TRENT310 has a spectacular reputation.TRENT310 has a spectacular reputation.TRENT310 has a spectacular reputation.TRENT310 has a spectacular reputation.TRENT310 has a spectacular reputation.TRENT310 has a spectacular reputation.TRENT310 has a spectacular reputation.TRENT310 has a spectacular reputation.TRENT310 has a spectacular reputation.TRENT310 has a spectacular reputation.
I use 21mm, it fits properly. I also have far more metric socket sets than SAE sockets kicking around.
Old 06-28-2012, 09:26 PM
ruschejj's Avatar
ruschejj ruschejj is online now
ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.
I use a 21mm socket. 3/4" drive. Nice good hold on that sucker and it's much easier to deal with. 1/2" drive just won't do......
Old 06-29-2012, 07:03 AM
PumpDoctor's Avatar
PumpDoctor PumpDoctor is offline
PumpDoctor has a very good reputation on FTE.PumpDoctor has a very good reputation on FTE.PumpDoctor has a very good reputation on FTE.
What are the lug nut torgue specs on the SRW. All I saw in the manual was 95ft lbs for F350 DRW. Is it the same for all Superduty trucks.
Old 06-29-2012, 07:58 AM
jlalanas's Avatar
I thought it was 165lbs......
Old 06-29-2012, 09:48 AM
ruschejj's Avatar
Sounds right j. I put my hand about 16" toward the end of my ratchet and apply most of my weight (175) which should net me about 165 ft-lb of torque on them. I worked it out years ago and don't think about it anymore.
Old 06-29-2012, 10:26 AM
Glockin' Bob's Avatar
Glockin' Bob Glockin' Bob is offline
Glockin' Bob is gaining momentum as a positive member of FTE.
165 ft/lbs is the spec in my owners book. I tighten mine with a 1/2" drive torque wrench, 21mm socket sounds right. I rotate the tires (SRW) every oil change which I do myself.
ipr socket size tcjhkbjt 6.0L Power Stroke Diesel 23 03-09-2015 06:06 AM
Socket size fuel filter macguy 6.7L Power Stroke Diesel 5 11-30-2012 08:01 AM
99 7.3 Starter Bolt Socket Size? Yougotthehit 1999 - 2003 7.3L Power Stroke Diesel 7 01-19-2012 12:07 AM
transfer case drain plug socket size bluescrew 1999 - 2003 7.3L Power Stroke Diesel 3 11-04-2011 12:27 PM
Socket Sizes For Oil And Fuel Filters? Fuzzy Willy 6.0L Power Stroke Diesel 3 08-15-2005 09:37 PM
Tags
f350, full, lug, nut, size, socket, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
