Bolts on ignition coil - Ford Truck Enthusiasts Forums
Old 06-27-2012, 08:25 PM
huber1010 huber1010 is offline
huber1010 is starting off with a positive reputation.
I just bought my F-150 in March, and I'm doing some routine maintenance to her. I'm trying to change the ignition coil, and I can't get the bolts off. They're the smallest bolt heads I've ever seen. I put a 1/4" wrench up to them to try and get them off and even that was too big. Any suggestions? Are these pretty standard bolts or did somebody in the past just try to frustrate me? Haha. Any help is appreciated.
Old 06-27-2012, 09:03 PM
ctubutis's Avatar
ctubutis ctubutis is offline
ctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputation
Metric, 5.5 MM? Try a SAE 7/32".
Old 06-28-2012, 02:01 AM
GLOCKREAPER's Avatar
GLOCKREAPER GLOCKREAPER is offline
GLOCKREAPER is starting off with a positive reputation.
The stock bolts are 5.5mm.
Old 07-14-2012, 10:11 AM
Thanks for the help! 5.5mm just like you guys said.
changing COP's bravoface777 1968-2013 Full Size Vans 20 03-03-2015 06:32 AM
Where to mount ignition coil? brokersteve 1973 - 1979 F-100 & Larger F-Series Trucks 7 01-06-2014 06:05 PM
84 F150 351W wont fire - Coil Pickup? 64deville 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 11 11-28-2009 03:48 PM
Ignition Switch Wiring +12v jfarcas 1973 - 1979 F-100 & Larger F-Series Trucks 8 11-29-2007 09:19 AM
Ignition problems (Switch ?) youngAZfordguy 1973 - 1979 F-100 & Larger F-Series Trucks 16 08-12-2004 10:27 AM
Tags
02, bolts, buy, coil, expedition
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
