Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1973 - 1979 F-100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1973 - 1979 F-100 & Larger F-Series Trucks Discuss the Dentsides Ford Truck SPONSORED BY:
  #1 (permalink)
Old 06-27-2012, 12:22 AM
FordRun's Avatar
FordRun FordRun is offline
Garage is empty, add now
FordRun is starting off with a positive reputation.
Ford truck what do you think
i have a 74 f100 360 4 speed i put new carb new plugs wires new clutch hade points taken out . points to electronic ignition. 2 wheel drive. only get 8 mpg in town. i guess 10 on highway. should this be right ? 2 bbl carb. duel tanks.
  #2 (permalink)
Old 06-27-2012, 01:51 AM
HIO Silver's Avatar
HIO Silver HIO Silver is online now
1973 Ford F-100
My Garage
HIO Silver has a great reputation on FTE.HIO Silver has a great reputation on FTE.HIO Silver has a great reputation on FTE.HIO Silver has a great reputation on FTE.HIO Silver has a great reputation on FTE.
Is it "right"? Let's just say it's not uncommon.
BUT, my brother has a 69 F100 2wd/ 2 bbl/360/c6 with 3.00 rear gears and pulled 15.7 mpg on the highwy.
What's your rear gear?
  #3 (permalink)
Old 06-27-2012, 07:15 AM
fmc400's Avatar
fmc400 fmc400 is offline
fmc400 is a splendid one to beholdfmc400 is a splendid one to beholdfmc400 is a splendid one to beholdfmc400 is a splendid one to beholdfmc400 is a splendid one to beholdfmc400 is a splendid one to beholdfmc400 is a splendid one to beholdfmc400 is a splendid one to behold
Sounds a little low; check idle mixture with a vacuum gauge, accelerator pump stroke, choke opening properly.
  #4 (permalink)
Old 06-27-2012, 08:35 AM
earthquake68's Avatar
earthquake68 earthquake68 is online now
earthquake68 has a good reputation on FTE.earthquake68 has a good reputation on FTE.earthquake68 has a good reputation on FTE.
I have a 300 six with a one barrel and get 12 on a good day, if that puts things into perspective.
__________________
Alan Fenstermaker
'79 F-150 300-6, 4 spd. 4x4
  #5 (permalink)
Old 06-27-2012, 08:56 AM
mikeo0o0o0's Avatar
mikeo0o0o0 mikeo0o0o0 is offline
mikeo0o0o0 is a name known to allmikeo0o0o0 is a name known to allmikeo0o0o0 is a name known to allmikeo0o0o0 is a name known to allmikeo0o0o0 is a name known to allmikeo0o0o0 is a name known to all
Quote:
X2, also check the air filter and the timing, make sure it's not retarded.
Wouldn't hurt to run a compression test to see what kind of shape the motor is in overall. A "worn out" engine won't get very good mileage regardless.
Remember though, these trucks were designed and built when gas was 35 cents a gallon. Mileage wasn't a big concern then. Even with 2WD your pushing over 4000 lbs of steel with all the aerodynamics of a brick down the road........but it's still fun, ain't it.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
