Go Back   Ford Truck Enthusiasts Forums > Diesel > 6.0L Power Stroke Diesel
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
6.0L Power Stroke Diesel 2003 - 2007 F250, F350 pickup and F350+ Cab Chassis, 2003 - 2005 Excursion and 2003 - 2009 van SPONSORED BY:
  #1 (permalink)
Old 06-27-2012, 12:18 AM
John Irwin John Irwin is offline
Garage is empty, add now
John Irwin is gaining momentum as a positive member of FTE.
Could synthetic oil kill o-rings?
I've documented some of my o-ring woes here before, and now I have more.
Quick history...updated the stc a couple of years ago, then put an e-bay o-ring kit in the stand pipes and dummy plugs when I changed injectors last fall. Made it 5000 miles and it wouldn't start hot. Tested it with a multimeter and got .54 volts, air tested it, and had a leak under pass side valve cover. Standpipe o-ring was washed out, and the other side was close behind. Put Ford standpipes in, made it 3 months, and it won't start hot. Same .54 volts hot, same leak under the pass side valve cover. This time it's the internal injector o-rings that seal to the high pressure oil rail. These are fairly new injectors, albeit cheap POS things, but the o-rings look like they're 20 years old. I'm sure they changed them, the outers were new, and these things were supposed to be rebuilt.
So question...could it be my oil? I use Rotella synthetic in the winter, and switch to conventional in the summer. Maybe I shouldn't be switching oils?!? Can't figure out why this thing is eating o-rings.
I put a new IPR valve in when I did the standpipes just to be sure.
__________________
2006 F350, Bulletproof egr cooler, home made coolant filter, STC, standpipes and dummy plugs updated, blue fuel pressure spring, CCV reroute, glowshift guages, VXCF9 strategy, 325/65/R18's, 345,000 km, will keep updating as they add up.
  #2 (permalink)
Old 06-27-2012, 01:41 AM
Yahiko's Avatar
Yahiko Yahiko is offline
Yahiko is a name known to allYahiko is a name known to allYahiko is a name known to allYahiko is a name known to allYahiko is a name known to allYahiko is a name known to all
Personally any O-ring from Ebay would be on my suspect list.
As for the injectors. When you say cheap I would wonder if
they install new poor quality ones or reuse the old ones.
The key to getting good parts is traceability to a known
good source with the preference being from that source
with out any middle man.As for the oil killing them.
You could say yes or no. Just depends on if they are
made out of the right compound.
I would leave the oil type the same year round
and if you MUST change the weight use the same
brand and type.
Sean
__________________
Big Cat and not the one on the tail pipe
"How do you eat an elephant? One bite at a time!"
Mods Blue Spring, High Idle(BCP), Coolant Filter,SCT from http://www.gearheadautomotiveperformance.com/
HFCM Drain Plug, Nav System, Leveling Kit, Backup Camera, HID Fog 3000K & Driving Lights 4300K
  #3 (permalink)
Old 06-27-2012, 02:21 AM
vectrex's Avatar
vectrex vectrex is offline
2005 Ford F-250
vectrex is gaining momentum as a positive member of FTE.
I did quite a bit of research before switching to Rotella, and a thread title search on 'Rotella' here will yield multiple conversations on the subject (some a tad heated). There are enough people who have been using Rotella for long periods of time that I am confident enough to run it in my 6.0.
It meets Fords recommended specs, there is NO reliable data pointing to any known issues with it (or none that I could find). If it were capable of eating o-rings, I don't believe it would be on the shelves long.
I plan on sending in samples after my second change to blackstone labs to see how well it held up with my driving habits.
  #4 (permalink)
Old 06-27-2012, 05:43 AM
MC5C MC5C is offline
MC5C has a good reputation on FTE.MC5C has a good reputation on FTE.
There are different types of O-rings, and vastly different qualities. They cost so little I can't imagine not using good ones, but they are the sort of thing that none of us really know much about far less how to reliably buy good ones, so how to tell if what came with your injectors were top quality? Synthetic oil is kinder to O-ring material than dino oil, anyway, per my research.
Brian.
Tags
ford, older, synthetic, van
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
