Barometric pressure sensor? - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Old 06-26-2012, 06:06 PM
Ken_C's Avatar
Ken_C Ken_C is offline
Ken_C is gaining momentum as a positive member of FTE.
Where is this sensor located? anyone got a picture? do they go bad? I was just wondering because ive noticed sometimes on a hot restart I get glowplugs coming on? not a big deal i guess. more of a curiosity. would it throw a code? iguess if I had AE i could figure it out. but my laptop runs ubuntu linux. they should make it operating system independent. like have its own OS on the cd which could be bootable?
Old 06-26-2012, 06:23 PM
fordpride's Avatar
fordpride fordpride is offline
fordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant future
It's under the dash by the stearing column it looks like a relay plugged into some wires
Ken if you wanna try one before you go but one shoot me a pm with your address. I have a good used one I'll ship you and if it fixes issue you can have it. If not mail it back
Old 06-26-2012, 06:46 PM
fordpride's Avatar
Could be EOT sensor
Ohm the sensor when engine is cold
K Ohms__Volts____TempF___Temp C
826______4.75______-32______-36
785______4.75______-30______-34
575______4.73______-22______-30
525______4.72______-20______-29
365______4.68______-10______-23
300______4.65______-4_______-20
250______4.63______0________-18
192______4.6_______10_______-12
173______4.55______14_______-10
139______4.49______20_______-7
103______4.4_______30_______-1
98_______4.38______32_______0
64_______4.18______40_______4
59_______4.13______50_______10
43_______3.92______60_______16
37.3_____3.8_______68_______20
33.6_____3.73______70_______21
26.8_____3.53______80_______27
24.3_____3.44______86_______30
21.5_____3.32______90_______32
17.2_____3.08______100______38
16.1_____3.01______104______40
13.9_____2.84______110______43
11.2_____2.59______120______49
10.9_____2.56______122______50
9.34_____2.38______130______54
7.55_____2.11______140______60
6.28_____1.89______150______66
5.34_____1.72______158______70
5.32_____1.71______160______71
4.48_____1.52______170______77
3.84_____1.37______176______80
3.75_____1.35______180______82
3.17_____1.18______190______88
2.8______1.09______194______90
2.68_____1.04______200______93
2.2______0.88______210______99
2.08_____0.86______212______100
1.87_____0.78______220______104
1.56_____0.67______230______110
1.33_____0.59______240______116
1.19_____0.53______248______120
0.38_____0.17______CEL Below This
__________________
Old 06-26-2012, 07:24 PM
Ken_C's Avatar
Just ordered a new Low pressure oil sender. F6TZ-9278-AA. mines leaking and making a dirty mess of the HPOP res. I will let ya know on the BARO. i have the front diff leaking around a couple bolt heads to worry about. i had to drive over a curb to avoid killing an idiot who started to turn left in front of me then changed her stupid mind and stopped right in front of me. since then the front diffs been wet with gear oil.
Old 06-26-2012, 11:16 PM
fordpride's Avatar
Offer stands just let me know off you want it. It's free
Old 06-26-2012, 11:17 PM
Talyn's Avatar
Talyn Talyn is offline
Talyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud of
Gp's will always come on no matter what.
Just depnds on how long.
Old 06-26-2012, 11:18 PM
fordpride's Avatar
Mine doesn't come on when up to temp.
Old 06-27-2012, 12:48 AM
nomad221's Avatar
nomad221 nomad221 is offline
nomad221 is starting off with a positive reputation.
Quote:
What is the cutoff temp ?
Old 06-27-2012, 06:19 AM
427 fordman's Avatar
427 fordman 427 fordman is offline
427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.
Mine don't come on either when up to temp. I think I read when the motor is up to 160? Can't remember for sure the temp.
Old 11-22-2012, 10:26 AM
TreesnFords TreesnFords is offline
TreesnFords is starting off with a positive reputation.
I am having similar issues. I just tested the eot. motor cold (around 50 deg F) ohms 77.8, volts 4.76. It does not really match up to the chart so not sure what to make of the sensor. Any thoughts?
Old 11-22-2012, 12:52 PM
Hussler's Avatar
Hussler Hussler is online now
Hussler is a name known to allHussler is a name known to allHussler is a name known to allHussler is a name known to allHussler is a name known to allHussler is a name known to all
Quote:
About 135* F.
Cant find The Coolant temp sensor and Oxygen Sensor MelvilArnt 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 13 11-02-2016 03:27 PM
Compare Baro,EBP,MAP on TorquePro Cell's 1999 - 2003 7.3L Power Stroke Diesel 4 10-02-2014 04:43 PM
code p2197 thunderbird1986 1968-2013 Full Size Vans 3 10-21-2013 08:30 AM
melted dpfe sensor carlakally New Member Introductions 1 04-23-2013 04:19 PM
O2 sensor location on 04 F150 offroad17 Exhaust Systems 13 10-30-2008 08:32 PM
Tags
20, arizona, auto, california, car, general, insurance, manager, motors, powered, regional, sales, smf, vans, western
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
