Differential Torque Specs - Ford Truck Enthusiasts Forums
Old 05-08-2003, 03:23 AM
TexasGuy001 TexasGuy001 is offline
TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.
I have a 1995 F-150 w/ 8.8 rear. I can't seem to find this information in my Chilton's. I need to know the torque specifications for the differential cover bolts and the bolts that hold the driveshaft to the rear end. I really can't believe this manual doesn't tell what they are.
Thanks
Old 05-08-2003, 09:03 AM
steve83's Avatar
steve83 steve83 is offline
steve83 is starting off with a positive reputation.
The Haynes manual has those specs, but you can also find them here.
Old 05-08-2003, 11:59 PM
Hey, Thanks for the information. Thats an interesting web site. Do you know anything about the 9.75 upgrade they talk about on there?
Old 05-09-2003, 01:34 AM
Ryan50hrl's Avatar
Ryan50hrl Ryan50hrl is offline
Ryan50hrl is a splendid one to beholdRyan50hrl is a splendid one to beholdRyan50hrl is a splendid one to beholdRyan50hrl is a splendid one to beholdRyan50hrl is a splendid one to beholdRyan50hrl is a splendid one to behold
i belive the torque spec is 30 ft-lbs...but i'd look it up anyhow thats just off the top of my head. I usually just tighten them good and tight. LOL
Old 05-09-2003, 08:46 AM
steve83's Avatar
I'm preparing to swap to a '97-up rear axle with disks when my tires wear out, so I'm thinking about getting a 4-link coil-sprung 9.75" instead of another 8.8". I read thru that conversion once, but I don't remember much if anything about it. I'd rather do it myself so I know exactly what I'm getting.
Old 10-15-2011, 01:17 PM
Budmann Budmann is offline
Budmann is starting off with a positive reputation.
Rear Pinion Seal Torque Specs
I've been trying to find the torque specs for the pinion nut after replacing the seal. One guy said to NOT re-use the pinion nut. Any help on finding the torq spec would be appreciated.
Old 10-15-2011, 04:19 PM
EPNCSU2006's Avatar
EPNCSU2006 EPNCSU2006 is offline
EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.
The pinion nut is a lock-nut so it should be replaced any time it is removed. There is not a torque spec per se on the pinion nut. You have to gradually tighten the new pinion nut until it takes the same amount of torque to rotate the pinion as it did before disassembly.
How'd you find such an old thread?
Old 10-15-2011, 10:34 PM
GoinBoarding GoinBoarding is offline
GoinBoarding is gaining momentum as a positive member of FTE.
X2^^^
There is no torque spec on the pinion nut.
Take the differentail out. Axle shafts, carrier.
Put a NEW crush sleeve on the pinion (goes between the two pinion bearings).
Use a NEW pinion nut.
You need a beam style inch-pound torque wrench.
This is so you can measure how much torque it takes to turn the pinion gear with only the bearing drag as a source of resistance.
You need a pinion flange holding tool (just use a peice of flat stock with 2 holes drilled in it so you can bolt it to the pinion flange and let the other end rest against the leaf spring).
Get the pinion nut tighten up so there is no longer play in the pinion shaft.
Now start tighting the pinion nut in 1/16-1/8 turn increments. Check bearing pre-load after each increment. Do this by taking off the pinion flange holder and using your inch-pound beam style torque wrench. Repeat this process until you see 20-30 inch-pounds of torque required to get the pinion to turn.
I would shoot for 20 with used bearings. Maybe 25 with new bearings. If you go above 30, disassemble and start over with a new crush sleeve.
THIS IS A CRITICAL PROCESS. Do this right and have a happy ever after with your 8.8".
Old 10-16-2011, 05:29 PM
Didn't realize it was a lock nut. Thanks for the tip.
As for the old thread, I just kept digging until I found a thread close to what I was looking for. Didn't even notice the date until after I posted my question.
torque specifications for the bolts scrambledlife 1997-2006 Expedition & Navigator 0 08-08-2015 12:25 AM
99 F150 driveshaft bolt torque spec FordLou 1997 - 2003 F150 1 10-01-2013 07:48 PM
Rear Differential Leak carolinaborn82 2004 - 2008 F150 6 02-17-2012 06:39 PM
8 Bolt Differential Cover for '62 Econoline elmcity88 Ranchero & 1961 - 1967 Econoline 2 08-11-2011 02:00 PM
Rear differential leaks stewartfan 2004 - 2008 F150 4 09-22-2009 08:58 PM
Tags
05, 88, 975, cover, differential, differentiol, end, f150, f250, ford, rear, rearend, spec, specifications, specs, torque
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
