So, I've replaced the sender and tried grounding the sender wire with no response. The gauge always reads low "C." The sender wire is also in continuity with ground. It seems nearly impossible to trace this thing. What are my next steps?
I had the same problem on my 92, grounded the wire and no response from the gage. Wound up being a blown fuse. i do not remeber which one, but I would suggest checking all of your fuses.
