You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
No frame differences. Only difference is just in the VIN stamped into the frame.
A slightly change came in 52 when the front motor mount brackets were different design.
__________________
1951 Ford Panel
1952 Ford Panel
1937 Chrysler Airflow C17
...and way too many Bonus Built/Economy Built parts... http://www.bonusbuiltpanels.com/- under construction
Found lots of great dimensions for F1's on this forum. Not sure how to post it, search for Julies Cool F1, I hope that will help. She posted some old Ford forms several years ago.
Julie is not a she, but a he. Let's not go into the details again.
__________________
1951 Ford Panel
1952 Ford Panel
The only difference between an F1 and F2-F3 frame is the length.
__________________
1951 Ford Panel
1952 Ford Panel
Don't they also have different crossmembers? And is the gauge thickness of the steel thicker on the heavier trucks? I know there's some differences besides length.
Bottom line is, they are not interchangeable. F1 is it's own unit.
__________________
Wayne
52 Mercury M-1
among other things.
Yes Ilya you are certainly correct . . . thanks. I was focused on Lukas's original question. But I am interested in 52 Merc's observation about cross members, etc. F-1 to F-2. I'm trying to find a rack and pinion steering gear for my F-2. All the parts guys tell me that theirs won't fit but no one can tell me why. Obviously anything can be made to fit it just depends upon how many modifications need to be done. Has anyone done this or do they know why an R&P gear for an F-1 would not fit an F-2?
Sorry Lucas . . . I don't mean to hijack your thread but it is kind of on topic.
__________________ Pete
Northville, Michigan
2013 Jeep Grand Cherokee Overland Summit
1950 Ford F2 w/flathead V8/4-speed
They use the same solid beam axle, same spindles, drag links, etc..., so I don't see why not. Differences are 11" drums for the F1, 12" drums for the F2, plus the wheel bolt pattern. An optioned 9 leaf spring pack vs. the normal 8 leaf spring pack shouldn't make much difference if any. I'd be willing to bet it's their normal "disclaimer".
__________________
Nothing is so fatiguing as the eternal hanging on of an uncompleted task.
1948 F1
1949 F6
1999 Ranger ext. cab 4x4 DD
It looks pretty straight forward to me. He has 8 leaf springs and it looks like he has good clearance but I think that he has a '53 F-1 (see the large rubber stop). A little different than my '50 F-2. To complicate things more I am installing Posie Dual-Flex springs on the front which will give me a 2-3" drop. I'll have to do some measuring tomorrow . . . providing the heat takes a break. It was 97 deg here today !!!
Yes, Wayne, to be specifically correct, which I should have been, the F2-F3 frames do have different xmembers than the F1 frame. The transmission xmember is different, as well as there's at least one or two more xmembers because of the length. I don't believe that the gauge thickness of the steel in the frame was different. I believe that it began to change with the F4 model.
__________________
1951 Ford Panel
1952 Ford Panel
