Power Windows Issue - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Power Windows Issue
Old 06-25-2012, 11:04 PM
Troop4Christ Troop4Christ is offline
Troop4Christ is starting off with a positive reputation.
Power Windows Issue
Alright. I've scored the internet for days trying to find an answer to this..
I've got an issue where the power windows on my 2005 F350 Crew cab will work when I have just turned on the key. But after using them for a few seconds, they stop. If I reach down after a while w/ the truck up, the 601 circuit breaker is HOT to the touch. I tried paying $20 for a new one, installed it and I'm having the same issue. I can turn the key off, pull the CB, blow on it for a few seconds, plug it back in, and the windows will work for a few more seconds (this is how I got them to go back up).
That's it. JUST the windows, EVERYTHING else works fine. Radio, instrument panel, power mirrors backup radar etc..
I've also tried swapping the "accessory Delay Relay" w/ the "Upfitter relay" to no avail, issue persists. I have a hard time thinking it's a loose connection somewhere because:
A) The windows just stop working w/ ANY physical movement in the truck
B) I can recreate the issue w/ ALL the power windows in the truck (4 windows, Moon roof, and rear power slider) on multiple switches throughout the truck (even the one on the dash for the rear slider and the one on the ceiling for the moon roof).
Does anyone have any other ideas? I REALLY don't wanna take this thing into Ford for $150 just to have them tell me I missed something.
Thanks a lot..
Old 06-26-2012, 07:56 AM
projectSHO89 projectSHO89 is online now
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
The circuit breaker gets hot and opens for one reason: Too much current is being pulled through it. Only the power windows (including slider and moon roof) operate off this circuit breaker, so nothing else will be affected.
Does the circuit breaker also get hot when the truck moves regardless of whether the window switches are operated or not?
I'm thinking that you may have a pinched or chafed wire (circuit 400) that is shorting to chassis ground when the truck moves. Less likely might be a beverage was spilled into one of the door-mounted window switches or something else odd.
Old 06-26-2012, 01:19 PM
But then why would they work when just turning on the key and then stop working w/o the truck moving at all?
Old 06-26-2012, 01:27 PM
It may take several seconds for the thermal element in the breaker to heat up and open.
Old 06-26-2012, 01:29 PM
So nothing short of testing all the wires for the windows, is going to fix this issue? Ugh..
Old 06-26-2012, 03:45 PM
miserableloser miserableloser is offline
miserableloser is starting off with a positive reputation.
I am having a similar issue but I think mine is because the previous owner of this truck butchered the wiring somehow. My windows will work fine, radio will work fine also, then the next minute the radio and power windows won't work at all, then out of nowhere radio comes back on and windows work fine. Another oddity is that while the windows and radio aren't working if I turn my headlights on the clock which is on the radio works fine.
Old 06-26-2012, 03:56 PM
Another thing, i think it has something to do with the cig lighter. The whole problem started when i started using my phone charger in the cig lighter.
Old 06-26-2012, 05:24 PM
Looser,
None of your symptoms are the same. Please start your own, separate thread.
Old 06-26-2012, 05:27 PM
Quote:
No, just the power feeds to the window circuits, most likely. That's why it's important to clearly and accurately describe the conditions under which the circuit breaker cycles. See my unanswered question in post # 2.
Old 06-26-2012, 06:43 PM
<quote>Does the circuit breaker also get hot when the truck moves regardless of whether the window switches are operated or not? </quote>
Oh.. sorry.. didn't see that..
Yes.. it does, but only after I've operated the windows enough to trip it..
Old 06-26-2012, 07:08 PM
[quote=projectSHO89;11996690]Looser,
J/o
Stereo and Power slider questions.. KMAPRO 1999 to 2016 Super Duty 0 04-15-2016 02:37 PM
Constant power to radio, power windows, and moon roof please help!!! dmorenc1 1997-2006 Expedition & Navigator 5 01-19-2011 10:37 PM
Power rear window stopped working PSWP 2004 - 2008 F150 11 07-02-2008 04:22 PM
Moon Roof STILLEN/EXEPIDITION 1997-2006 Expedition & Navigator 5 05-18-2008 05:11 PM
Power sliding rear window kfactor 2004 - 2008 F150 35 04-29-2004 04:49 PM
Tags
broadcasting, california, mybb, northern, oregon, powered, public
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
