Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1957 - 1960 F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1957 - 1960 F100 & Larger F-Series Trucks Discuss the Box Style Ford Trucks SPONSORED BY:
  #1 (permalink)
Old 06-25-2012, 09:11 PM
blackedout blackedout is offline
Garage is empty, add now
blackedout is starting off with a positive reputation.
School me on heaters
I have a 59 I'm working on. The PO removed many unnecessary things like windshield wipers, a proper fuel tank, rear brakes, and a heater. Or so I believe, I have no idea if one was even installed from the factory or if this was an option. I don't even understand the vents in the kick panel. Any info would be greatly appreciated.
  #2 (permalink)
Old 06-25-2012, 11:12 PM
99hosss 99hosss is offline
1966 Ford F-250
99hosss is starting off with a positive reputation.
Hey Blackedout, I just bought a 60 250, will trailer it home tom., let you know about the vents soon. - I think you should see 2 holes in the firewall where the heater hoses went- right beside pass side hood hinge area
  #3 (permalink)
Old 06-26-2012, 04:07 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Guru
2013 Ford Escape
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Heater/defroster optional thru 1966, there were two types, fresh air or recirculating.
1957/60's have fresh air vents operated by cables with ***** on them. 1959/60's use specific right/left cables, while 1957/58's are the same right/left.
__________________
Bill // Retired Ford Parts Manager // SoCal Chapter member // Part Number Research: 1928/2001 FoMoCo vehicles.
2013 Escape SE FWD 2.0L Eco-Boost.
  #4 (permalink)
Old 06-26-2012, 04:37 AM
Col Flashman's Avatar
Col Flashman Col Flashman is offline
Col Flashman has a good reputation on FTE.Col Flashman has a good reputation on FTE.
As stated by, 99Hoss, look for Holes in the Firewall where the Heater should have been mounted.
What Number Dummy wrote.
The Louvers in the Kick Panels are the Fresh Air Vents for the Grill mounted in front of the Windscreen behind the back of the Hood.
They open & close w/ the Vent Pull Knobs mounted in the Dash, one on either side of the Steering Wheel.
Quote:
__________________
Cheers
Colonel Flashman
Vermilion '58 Mercury M-100 HP 312 I-6 w/ HP C-4
Blue '58 Mercury M-100 Panel 223 I-6 w/ M-O-M
Black 1893 Henry Ford Quadra-Cycle (replica)
My Replies Are Not Meant In An Offensive Way.... Ever, They Are Merely.... Straight Answers or Comments
  #5 (permalink)
Old 06-26-2012, 09:32 AM
Ford Parts Guru
2013 Ford Escape
Quote:
The Louvers in the Kick Panels are the Fresh Air Vents for the Grill mounted in front of the Windscreen (windshield) behind the back of the Hood (Bonnet).
"The US and Great Britain, two nations separated by a common language." -George Bernard Shaw
__________________
  #6 (permalink)
Old 06-26-2012, 11:29 AM
thanks for all the respones. I saw where the holes should be but haven't been punched open which leads me to believe there never was a heater/heater core installed on my truck. That would make sense originally being an Arizona truck.
Now to the air vents, do they bring in air from the engine compartment? How does one get warmth if not?
  #7 (permalink)
Old 06-26-2012, 11:52 AM
3414 3414 is offline
1960 Ford F-600
My Garage
3414 is gaining momentum as a positive member of FTE.
The fresh air comes from the base of the windshield. You only get warmth on hot days. You get cold on cold days.
  #8 (permalink)
Old 06-26-2012, 02:07 PM
Once Again! The Louvers in the Kick Panels are the Fresh Air Vents for the Grill mounted in front of the Windscreen behind the back of the Hood.
__________________
Cheers
Colonel Flashman
Tags
1957, ford, heater, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
