power to manual window conversion - Ford Truck Enthusiasts Forums
Old 06-25-2012, 09:51 PM
bikeymikey's Avatar
bikeymikey bikeymikey is offline
bikeymikey is starting off with a positive reputation.
Just trying to figure out if this is the route i wanted to take. i've done a search and read up on the threads regarding this subject, i probably will try to rebuild the motors on the windows for my '89 4 door f350 4x4. but just in case that doesn't work out, i'm wondering if i can take a manual window regulator plus the interior panel off of any f series truck or does it have to be from a 4 door f350? i understand that some parts of the panels might not match up with the dash if they're from a different generation truck.
thanks!
Old 06-26-2012, 09:00 AM
tjc transport's Avatar
tjc transport tjc transport is offline
i ain't rite
tjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputation
all you really have to do is drill a hole for the hand crank and leave the switches there till you find manual door panels.
as for the regulators, remove the power ones and replace with manual ones.
Old 06-26-2012, 09:07 AM
pfogle's Avatar
pfogle pfogle is offline
pfogle has a good reputation on FTE.pfogle has a good reputation on FTE.pfogle has a good reputation on FTE.
I think the easiest way would be to find manual doors at the boneyard.
Old 06-26-2012, 02:34 PM
bikeymikey's Avatar
that sounds like a good plan
Quote:
if i went this route, does the donor vehicle have to be a 4 door f350? or are the front doors all the same? i have an 89
Old 06-26-2012, 02:37 PM
jimbo285's Avatar
jimbo285 jimbo285 is offline
jimbo285 is starting off with a positive reputation.
Not trying to hijack, but can the same be said for the reverse? I have 94 XL with manual windows. Is there existing wiring in the door of my XL manual window doors? Can I get the motors, regulators and swithes from XLT door and plug n play?
Old 06-26-2012, 03:10 PM
jas88's Avatar
jas88 jas88 is offline
jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.
The wiring for pw is not there on manual window trucks so it is not plug n play.
Old 06-28-2012, 01:31 PM
bikeymikey's Avatar
still trying to figure out if the interior door panels of any f series truck will fit on the door of my 89 4 door f350.
Old 06-28-2012, 02:24 PM
i ain't rite
87 to 91 f-series and bronco will exact fit.
92 and newer will sorta fit, but not exactly
window roller in '56 f-350 gusThe56f-350 1948 - 1956 F1, F100 & Larger F-Series Trucks 10 06-29-2016 12:13 AM
power window wiring loom dkanik 1999 to 2016 Super Duty 0 04-25-2015 01:38 PM
F 350 drivers side power window problem poppop50 1999 to 2016 Super Duty 10 08-03-2013 06:32 PM
87 door panels on a 92 door? Bootlegger's Deluxe 1987 - 1996 F150 & Larger F-Series Trucks 4 02-14-2012 12:22 AM
92 F150 POWER WINDOW MOTOR REPLACEMENT cato47 1987 - 1996 F150 & Larger F-Series Trucks 19 01-03-2012 10:19 PM
Tags
94, 99, broadcasting, california, conversion, f150, ford, manual, mybb, northern, power, powered, public, regulator, window, windows
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
