How many fuel filters 86
Old 06-25-2012, 07:30 PM
1986stepsidef150's Avatar
1986stepsidef150
1986stepsidef150 is offline
How many fuel filters are there in a 86 f150 5.0. Ive been changing everything out to get her to run a lil better. I replaced the inline one and seen the black canister behind the high pressure pump. Is there a filter in there? If so do you need to replace it or just keep it out? What is the purpose of the canister? I was going to try to open it but a little worried to break it since its plastic. If i did break it I wouldnt know where to find one
Old 06-25-2012, 07:36 PM
ri_truck_guy's Avatar
ri_truck_guy
ri_truck_guy is offline
Just the one...canister type on the drivers side frame rail before the high pressure pump. You do need to replace it. Drain pressure off the system by tripping the inertia switch and trying to start the truck, then just turn the lower plastic part of the canister off. It's easy with a strap wrench.
Old 06-25-2012, 07:39 PM
1986stepsidef150
On my truck from the tank is the canister the high pressure fuel pump then a inline filter. Its good to know that there is a filter in the canister. I wasnt sure and didnt want to rick breaking it for nothing. Its tight as heck on there
Old 06-25-2012, 07:42 PM
ri_truck_guy
You actually have a low pressure pump in the tank as well. That's why its good to bleed pressure off the system before opening the canister. There also is a large but very thin O-ring seal that seals the canister. It's a PIA to get in place.
Old 06-25-2012, 07:48 PM
1986stepsidef150
Yeah when i got the truck i put on a new tank sending unit and low pressure pump and I replaced the metal inline filter. recently she start running like crap so ive been giving it a tune up. When I went to get a fuel filter there was two options. The inline and a little cardboard hockey puck looking thing. Thats what got me thinking it could be in there. I hope its a simple fix like that. The truck sat from 03 till last january when I got it im sure it needs replaced
Old 06-30-2012, 07:56 AM
1986stepsidef150
Ok i got it out. Had to buy stripped bolt sockets and broke fuel lines but it was deff my problem. Ive never seen a filter that bad in my life
oldford65
08-07-2013 10:19 PM
f100beatertruck
09-03-2007 08:25 AM
azjay
Bronco II
07-20-2007 03:08 AM
f100beatertruck
01-26-2005 01:14 PM
Mike O.
02-06-2000 03:40 PM
Quick Reply: How many fuel filters 86
