Transmission temps. What is normal?
#31
I have the 6.0 cooler on a otherwise stock 7.3 X and can say what Mark says about that there is not enough airflow through the cooler at slower speeds is very true.
I just made a trip from MO to Grand Lake, Co down I-70, then up US40 through the Berthound Pass at 11,700 feet. My transmission temps went to 218 at the highest point. At 45/50 mph that is where the temps stay, but as soon I get over 55 mph the temps start falling and will drop to the 180 range.
I tow a 35 trailer that is close to 9000 lbs. I have considered adding an electric fan to the front that I can use when I am driving in the city or pulling uphill. I have found even in 95 temperatures driving 65 the temps will stay in the 180 range on normal roads with the 6.0 cooler.
Mike
Mike
I will say that the Torque Converter lock up makes a noticeable difference with the DP tuner under 40mph.
I'm towing down to Buena Vista on July 19th for an event I sponsor. Hwy 285 is a good test, so I am interested to see how it does.
fullsize4wd
08-17-2013 06:10 PM
Rubidon
07-08-2012 06:38 PM
82F100PU
04-16-2004 02:11 PM
05, 35s, 73, 73l, day, excursion, f250, hot, mpg, normal, overheating, temperature, temps, trans, transmission, transmisson
