Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > International Region > Australia Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Australia Chapter Join Chapter , Leader: ChunderDownUnder
  #1 (permalink)
Old 06-25-2012, 03:59 AM
Ratkat's Avatar
Ratkat Ratkat is offline
Garage is empty, add now
Ratkat is gaining momentum as a positive member of FTE.
Ok I've done it again
Spent more money on the truck. Picked up a full F350 Dually conversion this afternoon. Fitting is booked and work will comence on the flares next week.
__________________
Geoff
2002 F250XLT Superduty AFe 11, CCV, HPx, FRx, Air Dog, Ceramic Coated Manifolds and bellowed up pipes, 3.5" to 4 " Magnaflow, 38r high flow outlet ceramic coated, Stage 11 injector's, 20 cent mod (only for Australians) JW Trans DB sump, Di Pricols, 2x pyro, boost trans, Dp, modified stock, 40tow, 60tow, High idle, 60 econo, 80econo, 120race, drive thru, Low fuel so far.
  #2 (permalink)
Old 06-25-2012, 04:32 AM
ChunderDownUnder's Avatar
ChunderDownUnder ChunderDownUnder is offline
ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.
Finally arrived m8. Grab some pics if ya can
__________________
Brian
03 F250 XLT LB . Full Engine build with all the goodies. Tuned by Matt
- cant wait until my motor blows so I can blame someone else -
join the Australian Chapter here-Join Chapter
  #3 (permalink)
Old 06-25-2012, 05:39 AM
SSSimon SSSimon is offline
2005 Ford F-250
SSSimon is gaining momentum as a positive member of FTE.SSSimon is gaining momentum as a positive member of FTE.
Love to see the pic too! So it's the F350 dually rear axle and springs going in and flares going on the tub then?
You might want to look for those MOR/Ryde shear-rubber rear shackle replacement blocks to soften up the unladen ride!
http://www.ford-trucks.com/forums/at...1&d=1336485651
__________________
Mods done: lots of cheap mods (Hutch, IC boots, plenum inserts, IH uppies, HPx, AIH delete, EBPV delete, hi flow outlet, CCV mod, OCR, Superchips, Zoodad, 6637, 4" TB exhaust, JW valvebody, coolant filter, FRx, '05 HD lights with switch bypass relays, B100 ready fuel system)
Mods NOT done: big oil, big brakes, big turbo
Next mods: ? tuner, G2WW (on the shelf), alloy diff covers
Australia: where Mechanics use spanners and Plumbers use wrenches...
  #4 (permalink)
Old 07-19-2012, 06:36 PM
Greywolf's Avatar
Greywolf Greywolf is offline
WILD CARD
1989 Ford Ranger
Greywolf has a superb reputationGreywolf has a superb reputationGreywolf has a superb reputationGreywolf has a superb reputationGreywolf has a superb reputationGreywolf has a superb reputationGreywolf has a superb reputationGreywolf has a superb reputationGreywolf has a superb reputationGreywolf has a superb reputationGreywolf has a superb reputation
I've thought of doing something like that to a 1/4 ton Ranger in the future.
~But then, I freely admit that I AM a madman...
__________________
Think outside of the box - especially if you built it yourself
  #5 (permalink)
Old 07-19-2012, 07:19 PM
Ratkat's Avatar
Yep Simon the full 350 rear flares and all out of an 06 350 has the same ratio so I dont have to change the front. At this stage the flares have been plastic welded and ar gettin put under primer. I am waiting on some clips and stuff from the states. Once falres are fitted it will go in to have the diff put in. Had not seen the shackle rubers before do you know wherer to get them from ?
__________________
Geoff
  #6 (permalink)
Old 07-19-2012, 08:07 PM
Greywolf's Avatar
WILD CARD
1989 Ford Ranger
A thing I thought about to get wider tyres under the back of my Ranger project truck was to get two sets of bed fenders - and then slice & weld them so that they went out wider....
If a set were halved with a saw - a strip of metal could be welded too -
But braces might be needed to prevent the weld seam from breaking
Food for thought
http://www.ford-trucks.com/forums/10...-roadster.html
It may take extraordinarily wide tyres to get all of that power to the ground in the form of traction, given that the truck is so light and small...
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
