Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1957 - 1960 F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1957 - 1960 F100 & Larger F-Series Trucks Discuss the Box Style Ford Trucks SPONSORED BY:
  #1 (permalink)
Old 06-25-2012, 12:01 AM
bayou58 bayou58 is offline
Garage is empty, add now
bayou58 is starting off with a positive reputation.
newbie here just bought a 58'
Just bought a 58' f100 223 with 3 speed borg has clifford intake and headers along with a holly 4 barrel ill post pics as soon as i figure that out. Trans first gear is clunky not sure if i should rebuilt it or upgrade? Any advice
  #2 (permalink)
Old 06-25-2012, 12:44 AM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.
Welcome to FTE!
Congrats on your '58. We had a '58 F600 on the farm, and I have always liked the look of those.
Your trans is non-synchro in first gear, and thus it will grind, even at a standstill. You will not be able to easily downshift it into first either, although with enough practice and rev matching, it can be done.
Try shifting it into 3rd, then 2nd then 1st when at a stop, or at least 3rd then first. This will stop all motion inside the trans. (the input shaft spins due to friction from the pilot bushing and sometimes a little clutch drag)
I'd say try 2nd, but remember, the 2nd gear synchro leads a tough life, so best try not to use it just to "still" the trans to make first easier to engage.
Good luck with it!
  #3 (permalink)
Old 06-25-2012, 08:46 AM
Its not that type of clunky... its "got a broken tooth" clunky when driving in first lol
  #4 (permalink)
Old 06-25-2012, 10:47 AM
Oh.....
Millions served, you may be able to find one easily. If you get lucky, you might even find one with an OD unit on it.
  #5 (permalink)
Old 06-25-2012, 02:54 PM
Can u tell me which transmission would be compatible with that bell housing.
  #6 (permalink)
Old 06-25-2012, 04:23 PM
Your bell to trans is a "square", thus you need a trans with that square, or a later one that is drilled for both.
These are BW T85, 86, 87 model transmissions iirc, so those would be ones to look for.
If you are looking for a different trans, the T98 will have the square pattern also. Some other later transmissions have both patterns or can be drilled for the older pattern.
  #7 (permalink)
Old 06-25-2012, 05:33 PM
Ok thanks it has a t85c-1 now
  #8 (permalink)
Old 06-25-2012, 07:34 PM
spurredon's Avatar
spurredon spurredon is online now
spurredon has a good reputation on FTE.spurredon has a good reputation on FTE.
If you get a 63' or newer three speed, it will be syncd' in first gear. A lot less grinding. There are plenty of cluster gears out there if you want to rebuild your existing.
Also, welcome to FTE!
  #9 (permalink)
Old 06-25-2012, 07:41 PM
Thanks alot. I'm guessing the newer trans would not match my bell housing. Also do I have to tear down the existing trans to get the proper cluster?(count teeth)? Or can I use a part number?
  #10 (permalink)
Old 06-25-2012, 08:18 PM
spurredon's Avatar
You will able to count teeth if you remove the cover.
I have a 64' 3-speed behind my 223. But as 85e150six4mtod was saying, there are a lot of other options.
  #11 (permalink)
Old 06-25-2012, 08:40 PM
Check your trans code--and then check this:
http://www.ford-trucks.com/forums/11...nsmission.html
There was a light and heavy in the F250, so you might look for the T89 also.
The Ford "303" top loading 3 speed came out in '63.
It may have had both patterns in the first few years of production. Not sure on that. When you are trans shopping, the difference in patterns will be clearly visible. There is a comparison here, with a trans that has both patterns:
Toploader Imposters
More trans decode info here:
http://www.ford-trucks.com/forums/11...ease-help.html
Picture of the 303 3 speed--very easy to ID without removal:
http://www.google.com/imgres?q=ford+...:16,s:15,i:175
Tin cover and two shift arms are the main clues. Note this one has a Mustang or Cougar floor shifter on it. Column shifter arms are different.
  #12 (permalink)
Old 06-26-2012, 04:22 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Guru
2013 Ford Escape
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Warner T-85 is an overdrive transmission. wasn't available until 1965, F100's only.
1957/60 F100: TRANS code stamped on Rating Plate:
A = Ford 3 speed manual light duty (no first gear syncro) / B = Warner T-86 3 speed manual with overdrive (no 1st gear syncro) / F = Warner T-98 4 speed manual / G = Ford-O-Matic (w/a 223 I-6).
Ford type 3.03 3 speed manual all syncromesh trans introduced in 1963.
__________________
Bill // Retired Ford Parts Manager // SoCal Chapter member // Part Number Research: 1928/2001 FoMoCo vehicles.
2013 Escape SE FWD 2.0L Eco-Boost.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
