7.3 vs v10 gas - Page 3 - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
7.3 vs v10 gas
  #31
Old 06-25-2012, 02:11 PM
KES08's Avatar
KES08 KES08 is offline
KES08 is starting off with a positive reputation.
Quote:
Originally Posted by mudd hog View Post
Thanks. Could I later reagear if I can't find a truck with the right gears
How much would that cost
Right now I am looking at a 2000 F 250 with the v10 it has the off road package not sure about gears
It costs roughly $2k to regear the truck. Definetly worth it too if you get a good deal on a truck without 4.30's
  #32
Old 06-25-2012, 02:17 PM
dkf's Avatar
dkf dkf is offline
dkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to behold
Yes. You can get gears down to 5.38 for the front and rear diffs. What gears you go with depends on what size tires you plan on running.
  #33
Old 06-25-2012, 02:19 PM
FordGuy85's Avatar
FordGuy85 FordGuy85 is offline
FordGuy85 is starting off with a positive reputation.
The truck in my Sig. Is 5.4l. It does pretty good in the mud. But I wish I had a locker. Iv been stuck a couple of times., but those places I should have had some forward momentum to get through. I think the lighter gas engines do a tad better off road. Iv seen a couple diesels sink in mud fast. For what you want to do, I think a gas engine will do fine.
As said before, these trucks are already extremely heavy. If you go dieael, you will want a very tall tire. Maybe even some tractor tires. But then on the other hand, that setup won't be the beat for towing and daily driving.
  #34
Old 06-25-2012, 02:37 PM
mudd hog mudd hog is offline
mudd hog is starting off with a positive reputation.
ok thanks for all the help
  #35
Old 06-25-2012, 02:59 PM
kd0axs's Avatar
kd0axs kd0axs is offline
kd0axs has a great reputation on FTE.kd0axs has a great reputation on FTE.kd0axs has a great reputation on FTE.kd0axs has a great reputation on FTE.kd0axs has a great reputation on FTE.
One thing that hasn't been mentioned here is your budget.
How much are you looking to spend?
Are you paying cash outright or financing?
If financing, how much cash do you have to put down?
How much can you afford per month for a payment and insurance?
Have you considered how much you will drive it and the price of fuel? It would really suck to go buy that nice truck and not be able to drive it because you can't afford to fill the tank.
  #36
Old 06-25-2012, 03:05 PM
Plan on buying from owner on Craigslist around 4000 dollars
Already have f150 that gets 16 mpg
This truck will be mostly for work play and show
  #37
Old 06-25-2012, 03:17 PM
maverick22's Avatar
maverick22 maverick22 is offline
maverick22 has a good reputation on FTE.maverick22 has a good reputation on FTE.maverick22 has a good reputation on FTE.
I wouldn't be pulling it on a trailer maybe just the tractor which is a 120 horse massy that would be the heavest I would ever tow
How often and how far would you be hauling the tractor? It could easily weigh 10-15,000lbs + the weight of the trailer. That's still within the capabilities of the v10 but if it was frequent and cross country you might want to think about a diesel though depending on what it actually weighs.
Have you guys had any trouble with the trannys on the 2000 v10's
If you're talking about automatics, the 4r100 in the 99-2004 gas trucks is somewhat of a weak link. It can be made nearly bulletproof but that's going to cost you. If it's in your price range you might look at 2005+ trucks, those gas engines have the better 5r100 or TorqShift transmissions. Of course if you want a manual then they're pretty strong regaradless of year.
Don't let the "off road package" fool you. All it consists of is skid plates, a sticker and some junk shocks. It should have the limited slip rear end as well but don't be fooled by that either, it's REALLY limited. For frequent mudding I would want a better rear (and maybe front) differentials anyway so if you find a truck w/out the off road package but the gears you're looking for, go for it. A good limited slip (Detroit TruTrac) will likely cost $1,000+ per axle. The only thing good about the off road package is the skid plates and you can put them on yourself.
  #38
Old 06-25-2012, 03:36 PM
kd0axs's Avatar
Ok, that changes things a bit then.
You can pretty much forget about getting a truck with a 7.3 for 4 grand, unless it has a ton of miles on it and needs work. The 7.3s hold their value and people don't let go of them cheaply. A decent truck with a 7.3 is still going to get around 10 grand, maybe even more.
For $4000, you are probably going to be looking at a 99-2000 with the 5.4 or maybe the V-10, likely with higher miles and probably needing some minor work.
  #39
Old 06-25-2012, 09:12 PM
Snowseeker's Avatar
Snowseeker Snowseeker is offline
Snowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputation
I also agree the V10 is the right choice for you.
  #40
Old 06-25-2012, 09:57 PM
CraigOutdoors's Avatar
CraigOutdoors CraigOutdoors is offline
CraigOutdoors is gaining momentum as a positive member of FTE.
Also how is acceleration compared to the 7.3
It'll peg your speedo quicker than you realize according to my experience.
  #41
Old 06-28-2012, 01:53 AM
Fosters Fosters is offline
Fosters is gaining momentum as a positive member of FTE.
Stock for stock, a 4.30 geared v10 is about even with a 7.3. Once the mods come in, the 7.3 walks away hands down. For mudding, you want wheel speed to fling the mud off the tires and have that momentum. The v10 will have the upper hand I'd say, because it likes to rev better than the 7.3, and it weighs less, but that shouldn't be your end goal. Like others have pointed out, you have two conflicting goals. I'd say turn the F150 you have now into a mud truck, and get the superduty for a tow vehicle. Best of both worlds.
  #42
Old 06-28-2012, 08:54 AM
GoCamping's Avatar
GoCamping GoCamping is offline
GoCamping is gaining momentum as a positive member of FTE.GoCamping is gaining momentum as a positive member of FTE.
Another vote for v10 (this coming from a 7.3 guy). My bud has an 03 v10 he just used to haul 10k across the country. Yes it has to rev but it does it well, just has to drink a lot of gas to do it. For your case you'll enjoy the v10 and none of the extra maintenance cost of the diesel.
  #43
Old 06-28-2012, 06:43 PM
there is a 95 f250 with a 460, auto transmission for sale in my town not sure how much is still stock 150000 miles
Is this a good truck not sure about price yet
Thanks for any info
  #44
Old 06-28-2012, 07:11 PM
kd0axs's Avatar
Thanks for any info
Those are great trucks but that 460 will really suck a lot of gas. We're talking less than 10 mpg in most cases.
  #45
Old 06-28-2012, 07:44 PM
$3500
Guy said it got 12 mpg
Thinking of replacing a 2004 V10 with a 7.3 Am I nuts? Fefanatic 1999 - 2003 7.3L Power Stroke Diesel 8 08-21-2016 04:35 PM
Lakeland area mudding Kieck7.3 Florida Chapter 0 06-07-2016 02:58 PM
6.0L Or 7.3L?? 1976and2001_250 1999 to 2016 Super Duty 48 05-23-2011 10:31 AM
V10 TO 7.3 POWERSTROKE MOTOR SWAP Highviewus 1997 - 2003 F150 2 01-18-2010 05:27 PM
Excursion swap a v10 for a 7.3 3244don Excursion - King of SUVs 3 08-28-2009 01:47 PM
Tags
2001, 73, 73s, air, auto, buy, cold, diesel, f350, faster, ford, hook, id, intake, manual, reasons, truck, v10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
