460 intake torque specs? - Ford Truck Enthusiasts Forums
Old 06-24-2012, 07:25 PM
Norton72's Avatar
Norton72 Norton72 is offline
Norton72 has a good reputation on FTE.Norton72 has a good reputation on FTE.
Arrow 460 intake torque specs?
I looked in my 1976 Ford shop manual and there are no torque limits specified for the intake manifold. It is listed, right next to Exhaust, but it is blank. Further down the page there is a table for "Torque Limits for Various size Bolts-FT. LBS. The bolts are 9/16 heads and the shaft is about 5/16 best I can figure. The value for 5/16-18 bolts is 12-18 FT. LBS., does this sound right? I would think it would be more, but when I took the intake off the bolts didn't seem to be very tight at all, so maybe this is right.
Three of the four corner studs came out with the nut, so I cleaned them up, checked the threads and put the studs back in with red Locktite. One of the bolts was actually a stud with a nut on it, and one of the other bolts was of the wrong type. Tomorrow I will see if I can find two replacement bolts and then hopefully I'll be able to wrestle the intake back on tomorrow evening.
Old 06-24-2012, 10:00 PM
Norton72's Avatar
25-30 ft. lbs. with light engine oil seems to be the average consensus based on several innerwebs resources.
Head Bolt/Stud Tech thread... RacinNdrummin Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 52 12-09-2016 12:24 PM
Installed ARP Studs Without Pulling Motor, Lifting Cab or Removing HVAC Box DSMMH 6.0L Power Stroke Diesel 118 08-17-2015 01:35 AM
Pressure Plate Bolts DeeV8er 1967 - 1972 F-100 & Larger F-Series Trucks 7 06-10-2013 10:47 AM
TORQUE SPECS.... timmyboy76 1999 - 2003 7.3L Power Stroke Diesel 1 12-31-2012 07:56 PM
Torque specs, Injector and IPR info I thought I would share Ziggy. 1999 - 2003 7.3L Power Stroke Diesel 24 05-10-2011 09:35 PM
Tags
460, ford, intake, manifold, specs, torque
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
