Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
  #1 (permalink)
Old 06-24-2012, 05:57 PM
locknload223's Avatar
locknload223 locknload223 is offline
2000 Ford Excursion
locknload223 has much to be proud oflocknload223 has much to be proud oflocknload223 has much to be proud oflocknload223 has much to be proud oflocknload223 has much to be proud oflocknload223 has much to be proud oflocknload223 has much to be proud oflocknload223 has much to be proud of
Would you buy this 6.0 tranny cooler?
Assuming it doesn't leak. The guy said the damage is cosmetic only. Looks like a 26 row? It came from a truck with a bad 6.0 and he's parting out the truck, the price for the cooler is $50. Should I hold off for a 31 row w/o damage? What do ya think? Thanks.
Click the image to open in full size.
__________________
Mike, PAA Member #127
2000 Excursion Limited PSD- ATS ported housing, Riffraff's FRx, HPx & I/C boot kit, 6.0 intercooler, DiPricol Optix- Pyro/Boost/Trans, DP Tuner-80t, Drive-Thru, 80e, 120race, 6637, 4" MBRP, AIH delete, 4" hanger, Vcodes/F350 blocks, Bilstein 5100s, Airbags, '08 diff cover, Dunlop Rover M/TMaxx 315s, '04 headlights, Auto Enginuity.
http://i19.photobucket.com/albums/b157/locknload223/Excursion/004Medium-4-1-1.jpg
  #2 (permalink)
Old 06-24-2012, 07:33 PM
cj45lc's Avatar
cj45lc cj45lc is offline
Garage is empty, add now
cj45lc has a very good reputation on FTE.cj45lc has a very good reputation on FTE.cj45lc has a very good reputation on FTE.
If it don't leak I'd say go for it, 26 or 31 row doesn't make any diff from what I've heard.
One good thing is you would never see it after you install it
__________________
2000 F250 7.3 Auto SCLB 2WD PHP Tunes AIS 4"TBEXH CCV Mod W-W
  #3 (permalink)
Old 06-24-2012, 08:14 PM
aawlberninf350's Avatar
aawlberninf350 aawlberninf350 is offline
Elder Blossom Wine
aawlberninf350 has a very good reputation on FTE.aawlberninf350 has a very good reputation on FTE.aawlberninf350 has a very good reputation on FTE.
I'd say no. Bends like that stress the metal, no telling when it will let go. Unless you have to tow something now and have no other money, walk away and do it right. A new one will cost you 3 tanks of fuel.
__________________
David
2002 F350 7.3 CCSB 4X4 sleeved AIS WW Mishimoto 6.0 IC 6.0 trans cooler 26 row RiffRaff: FRx Plenum Reinforcers AIH Delete Boots
Isspro EVs 50 cent mod Foil delete Hutch Harpoon DP Tuner Walker BTM 4R100 w/FTVB nlemerise AC mod Mile Marker 449ss RedHead 08 diff cover Fumoto DDM HID 55w 4500k Bilsteins DieselSite Coolant Filter Donaldson ELF7405
  #4 (permalink)
Old 06-24-2012, 08:22 PM
Deluxe06's Avatar
Deluxe06 Deluxe06 is online now
4000 rounds a min
2000 Ford F-350
Deluxe06 is a splendid one to beholdDeluxe06 is a splendid one to beholdDeluxe06 is a splendid one to beholdDeluxe06 is a splendid one to beholdDeluxe06 is a splendid one to beholdDeluxe06 is a splendid one to beholdDeluxe06 is a splendid one to behold
Hey Mike,
My question to you is, If you bought it would you really install it knowing it is damaged? You got a pretty nice rig there and I know you won't see it after install but you will know that it's damaged and if you are like me will worry about it.
__________________
Richard PAA#119
00F350CCDually;7.3L;ZF6,4"MBRP;DIY5"Tailpipe;Modde d Turbo 1.0 exhaust with Ported Shourd;EBPV as exhaust brake;Custom Air Intake with 6637;T500 HPOP;DPTuner-Stock,60e,80e,60t,80t,120r; 6.0 Intercooler;SBC;FRx;HRx;OCR;Bellowed Up Pipes;GlowShift Guages,Boost,EGT;AE, B.E.S.T map
  #5 (permalink)
Old 06-25-2012, 12:08 AM
Stewart_H's Avatar
Stewart_H Stewart_H is offline
1999 Ford F-250
My Garage
Stewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputation
Quote:
Yep, that's exactly what I was thinking.
Pass.
Stewart
__________________
The Brotherhood of FTE <-click the link
1999 F150 Lightning: WMS built block, 6lb lower, Monsterbox, Truetrac, CF driveshaft
1999 PSD F250 SC 4x4: 38R, Stage 2's, T-500, JW trans, Live Tuned, lotsa Riffraff stuff
2000 PSD Excursion 4x4: 38R, JW trans, F5, MBRP, AFE, OBA and Pre-Pump, V & B codes
Never Fry Bacon NAKED!
  #6 (permalink)
Old 06-25-2012, 09:00 AM
Crewcab Turbo's Avatar
Crewcab Turbo Crewcab Turbo is online now
2000 Ford F-250
Crewcab Turbo has a very good reputation on FTE.Crewcab Turbo has a very good reputation on FTE.Crewcab Turbo has a very good reputation on FTE.
I just bought a new 26 row from Ford and the price is hard to swallow, and I get dealer price and no tax. Crazy thing is you can buy a radiator from Ford with a Trans cooler in it for a hundred dollars cheaper. What's up with that? The way I looked at paying the insane price Ford wants for the cooler, was its protecting a $4000 transmission! $300 sounds cheap for the piece of mind. 98 degrees outside and I only have the 26 row cooler, no radiator cooler at this time and my thans never gets above 150 and that's with a well packed and overfilled bed full of wet firewood! Unless you can find one in premo condition and cheap, just buy the new one, you won't regret it!
__________________
2000 F250 Lariat
7.3, 4R100, 4x4, CC, SB, 4"lift, 315/75/16, AIS, GTP38R, Turbonetics outlet, 4" MBRP, Swamps 200/30 Hybrids, Swamps tunes, Swamps HI V/F IDM, IH bellows, Plenum inserts, Ic boots, OCR, HPx, FRx, Hutch/Harpoon, spin on prepump filter, Bosch pump, DIY 3/8 fuel lines to heads, Autometer boost, trans, pyro, coolant, Isspro EV2 fuel press, ELC, coolant filter, BTS vb, 6.0 trans cooler, Melling LPOP, traction bars, AE and more.
  #7 (permalink)
Old 06-25-2012, 09:18 AM
2000 Ford Excursion
Thanks everyone, I emailed him this morning and told him I was going to pass. I just wouldn't be able to fully trust it and my truck is worth a new cooler.
__________________
Tags
31, 60, cooler, row, run, tranny
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
