6.0 Stalls when turning left, and cuts out over bumps - Ford Truck Enthusiasts Forums
Old 06-24-2012, 11:47 AM
Asphalt_Cowboy Asphalt_Cowboy is offline
Asphalt_Cowboy is starting off with a positive reputation.
Our 2005 Ford Powerstroke E-360 6.0 family van recently started cutting out over bumps going down the freeway. It returns to idle for a second, and then runs again as normal. This only happens when there's a bump or series of bumps in the road. Numerous codes are on, including both the camshaft and crankshaft sensors, EGR, etc. It's all stock except for a tune. Turning left, it totally quits sometimes, especially if you turn left and hit a slight bump. Runs fine turning right. Any help would be greatly appreciated!
Old 06-24-2012, 12:11 PM
AGE mechanic AGE mechanic is offline
AGE mechanic is gaining momentum as a positive member of FTE.
Check your wiring harness.
Old 06-24-2012, 12:13 PM
Thanks for your response. Any parts of the wiring harness in particular? We removed and Dialectic greased all the connections we could get to this morning, still the same problem...
Old 06-24-2012, 07:06 PM
wwblue05's Avatar
wwblue05 wwblue05 is offline
wwblue05 is starting off with a positive reputation.
- just read posts on here 6-23-12 about shorting out of wiring in the steering column. Sorry i can't refer you directly to the thread or posts, but it was causing the truck to quit entirely, suddenly. I think the story was that a tech at a dealership found it or knew about it already when the poster had truck towed to dealer.
- I have noticed, after removing the air bag from steering wheel and modifying the wheel, that the key can be left in without the beeper going off, and the door won't stay locked-as if the key is in ignition when it is not, after working on the wheel. A short when turning the wheel sounds like a steering column wiring short, no?
Old 06-26-2012, 12:13 PM
powerstroke72's Avatar
powerstroke72 powerstroke72 is offline
powerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputation
Moved to the 6.0L Powerstroke Diesel forum.
Old 06-28-2012, 10:21 AM
Did you find the problem?
Old 06-28-2012, 09:03 PM
wwblue05's Avatar
6.0L stalls on turning left, on bumps, etc.
Quote:
AGE, not being sure who your Q. is directed at, I will answer. The work i was doing on my steering wheel was not electrical related at all. I loosened and peeled back the leather covering and another cover I had made and then sewed on. Then I took my die grinder to the flared ends of the overly large wheel spokes that are very uncomfortable to my hands, and which I could just barely reach my fingers around where the spokes meet the wheel rim. I cut away about 3/8" of material, both rubber and aluminum, from the corner of the spoke and rim. It is more comfortable, but still not like a good comfortable 3 or 4 spoke steering wheel should be, such as Ford has put on most of their vehicles.
Dash Lights greenf150flareside 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 3 08-31-2015 10:23 AM
HELP! Need advice for vibration. newbie2006 6.0L Power Stroke Diesel 1 06-22-2015 09:19 AM
2003 front end clunk fordex2003 Excursion - King of SUVs 5 03-03-2010 02:44 PM
Bump, clunk, bump, clunk ckstrawser Explorer, Sport Trac, Mountaineer & Aviator 25 12-22-2009 10:57 PM
cruise control cutting over bumps djwadds Excursion - King of SUVs 6 03-17-2009 01:20 AM
Tags
2006, bump, bumps, cuts, dies, edge, f250, f350, ford, gas, hitting, left, road, stalled, stalls, start, transit, truck, turning
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
