best oil for 6.8 triton v10 - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 06-24-2012, 09:31 AM
airmark's Avatar
airmark airmark is offline
airmark is starting off with a positive reputation.
good morning from arizona.it is a lovley 97 digrees at 727am. i am getting ready to do a full scale oil change on my 2000 350 sd.i know not a big deal for most of you but for me its a frustrating task. anyhow i have been reading on here that 6-7 qourts is what it should take. i also found a dip stick thread and am going to check that also . my qwestion is. what weight should i use for this truck here in az.i drive dureing the morning and then again at the hottest part of the day. some times its 117 digrees out. also synthetic or normal oil?
Old 06-24-2012, 09:55 AM
dkf's Avatar
dkf dkf is offline
dkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to behold
Your 2000 speced 5w-30 from the factory and that is what I would use. (Use 5w-30 in my 04')
As for oil brand, synth, dino and etc it really doesn't matter much. It just important you change it when required. I use a synthetic motor oil which is usually Pennzoil Platinum because it fairly inexpensive and is a good oil. I use Mobil 1, Valv Synpower and others from time to time if it is on sale but mostly the PP. A semi synthetic blend like the Motorcraft oil will be more than fine. Just use a quality name brand oil.
For the oil filter I would recommend the Motorcraft Fl-820s or Purolator Pure One. Both have the required silicone antidrainback valve.
Old 06-24-2012, 10:00 AM
AGE mechanic AGE mechanic is offline
AGE mechanic is gaining momentum as a positive member of FTE.
I run Amsoil in all my vehicles here in Phoenix.
airmark's Avatar
good deal. thank you sir.for some reason 10/40 allways comes to mind for oil. i think ill buy a book on my truck if they have on at the parts store.
Old 06-24-2012, 10:03 AM
airmark's Avatar
helo age mechanic......im in tempe.
Old 06-24-2012, 12:33 PM
jh818's Avatar
jh818 jh818 is offline
jh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputation
I use Mobil 1 5W-20 synthetic in mine. It calls for 5/20.
My next oil change, I'm going to use a trick I learned from this forum in removing the oil filter without making a mess. Use a 2 liter plastic bottle with the top and shoulder of the bottle cut away. Loosen the oil filter with the filter wrench before the oil starts oozing out. Then put the bottle over the filter like a sleeve and unscrew the filter in the bottle. As the oil oozes out, the bottle will catch it until the whole filter drops into the bottle. Then wipe the mount clean.
I hope this works.
Old 06-24-2012, 12:51 PM
airmark's Avatar
neat trick.ill have to try that next time. i gota say the oil that ran down my arm and into my arm pit felt kinda GGREAZZZY hahahaha
Old 06-25-2012, 02:48 AM
CPaulsen's Avatar
CPaulsen CPaulsen is online now
CPaulsen is gaining momentum as a positive member of FTE.
I use 5W20 in my 01 V-10. It specs 5W20 and have been using FoMoCo 5W20 semi-synthetic. And....6 quarts.
Old 06-25-2012, 09:20 AM
Kdr358's Avatar
Kdr358 Kdr358 is offline
Kdr358 is a splendid one to beholdKdr358 is a splendid one to beholdKdr358 is a splendid one to beholdKdr358 is a splendid one to beholdKdr358 is a splendid one to beholdKdr358 is a splendid one to beholdKdr358 is a splendid one to behold
Just pick a brand and stick with it, also make sure like others stated use only the fl820s or purolator pure one. Another trick to not making a mess is, take a small punch and make a hole on the lowest part of the filter and let it drain into The pan that way! I guess it's different for diesel owners who have 2 qts in the filter
Old 06-25-2012, 01:40 PM
FordGuy85's Avatar
FordGuy85 FordGuy85 is offline
FordGuy85 is starting off with a positive reputation.
I usually just crack the filter open and let it drain into the pan for a minute. Once is slows down or stops spewing oil unscrew it off. U might get a little oil on your hand but its usually ok because you already have some on your fingers from removing the drain plug.
Old 06-25-2012, 05:15 PM
aortizexcursion's Avatar
aortizexcursion aortizexcursion is offline
aortizexcursion has a superb reputationaortizexcursion has a superb reputationaortizexcursion has a superb reputationaortizexcursion has a superb reputationaortizexcursion has a superb reputationaortizexcursion has a superb reputationaortizexcursion has a superb reputationaortizexcursion has a superb reputationaortizexcursion has a superb reputationaortizexcursion has a superb reputationaortizexcursion has a superb reputation
I use 5W-30 on my 5.4 because that is what Ford says to use. Next oil change, I'm going to try 0W-30 for reasons outlined on BobIsTheOil website.
Old 06-25-2012, 06:08 PM
Fordfanatic4life Fordfanatic4life is offline
Fordfanatic4life has a very good reputation on FTE.Fordfanatic4life has a very good reputation on FTE.Fordfanatic4life has a very good reputation on FTE.Fordfanatic4life has a very good reputation on FTE.
i use 5-20 synth..
if you switch to Synth oil, expect to lose a litre of oil or so between changes.
the synth oils seem to more likely to drop oil level over a oil change life vs. dino oil.
just something to be aware of and keep an eye on every now and then.
Old 06-25-2012, 06:11 PM
TrdLtly's Avatar
TrdLtly TrdLtly is offline
TrdLtly has a superb reputationTrdLtly has a superb reputationTrdLtly has a superb reputationTrdLtly has a superb reputationTrdLtly has a superb reputationTrdLtly has a superb reputationTrdLtly has a superb reputationTrdLtly has a superb reputationTrdLtly has a superb reputationTrdLtly has a superb reputationTrdLtly has a superb reputation
Quote:
Do you have a good reference for that? I have considered that also and just wondering what the oil guys are saying. Thanks
Old 06-25-2012, 06:50 PM
Quote:
Here's a link to the BITOG article:
http://www.bobistheoilguy.com/motor-oil-101/
Basically, 0W-30 and 5W-30 oil is the same viscosity at operating temperature. It's with a cold start that the 0W is less viscous and more desirable.
Old 06-25-2012, 07:15 PM
skyline82 skyline82 is offline
skyline82 is starting off with a positive reputation.
mine will have rotella 5 w 40 when i change oilnext its a new to me truck.I used to work for a paving company explors to f 450 totly ford fleet they ran delo 400 15w40 the gasers would sound like hell on below 0 starts they sold at 150000 miles allways still running good still. I ran 5w40 in a 05 f150 w/5.4 and no issues for 80000 miles towing a skid loader had enough go but scarry on handleing & stoping but no motor problems
Is 230 F too high running up a 6 mile grade? coolfeet 6.0L Power Stroke Diesel 22 10-17-2015 10:58 PM
302 water pump help filthy6 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 09-21-2015 12:08 PM
What kind of oil do I need? 302,527miles 7.3idi Resendiz Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 7 09-03-2015 09:36 PM
1989 F250 lwb tommyknocker_7 1987 - 1996 F150 & Larger F-Series Trucks 3 07-19-2015 02:47 PM
Cooling system/oil system pressure question jpcjguy 1999 - 2003 7.3L Power Stroke Diesel 3 05-21-2015 07:59 AM
Tags
2002, 2007, 68, big, block, change, chevy, f250, ford, forum, kind, motor, oil, specs, triton, v10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
