F250 tailgate - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
F250 tailgate
Old 06-24-2012, 09:51 AM
caddy's Avatar
caddy caddy is offline
caddy is starting off with a positive reputation.
F250 tailgate
Anyone know how much would it cost to replace a tailgate on a 2009 KR. Mine was stolen this week. The tailgate had the backup camera.
Old 06-24-2012, 10:02 AM
edjunior's Avatar
edjunior edjunior is offline
edjunior is gaining momentum as a positive member of FTE.edjunior is gaining momentum as a positive member of FTE.
Check CraigsList. Here's at least one I found in Houston.
Ford F250 superduty tailgate
Where in Houston are you? Just so I know where to be more careful...just in case.
Old 06-24-2012, 10:19 AM
kd0axs's Avatar
kd0axs kd0axs is offline
kd0axs has a great reputation on FTE.kd0axs has a great reputation on FTE.kd0axs has a great reputation on FTE.kd0axs has a great reputation on FTE.kd0axs has a great reputation on FTE.
I'd be checking Craigslist for someone selling the stolen one. There have been quite a few cases up here in my area where people found there stolen stuff on CL, called the cops, and the people got busted.
You could try www.car-part.com to see if any junkyards in your area have them, I found one near me for $600. Then also figure on having it painted unless you are lucky and find one that's the same color as your truck.
Assuming you have full coverage, how much is your deductible? Might be better off just making a claim
Old 06-24-2012, 02:37 PM
caddy's Avatar
How much would it cost to have lock rekeyed to match ignition?
Old 06-25-2012, 12:12 PM
DarrellinCeres DarrellinCeres is offline
DarrellinCeres is gaining momentum as a positive member of FTE.
When you put it back
You can do like I did.I assume the newer ones still slip in like the older ones. I have a 99SD
It's a liitle bit more of a PIA to put it in but I removed the hinge took the plastic cup and turned it around so the slot was blocked. Bolted the hinge and tailgate in together so it can't be lifted out. I never could understand why they made them so easy to remove.
For added support I used a hose clamp around the hinge tightned from under the truck. Now it takes removing the hinge to removethe tailgate.
Old 06-25-2012, 02:17 PM
jdadamsjr's Avatar
jdadamsjr jdadamsjr is offline
jdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputation
I opted for this on mine:
Amazon.com: McGard 76029 Tailgate Lock: Automotive
keeps the honest people out and makes it a bit harder on the crooks !
Old 06-28-2012, 08:11 PM
caddy's Avatar
Does anyone know if you can add a factory camera to a tailgate that did not come with that option from the factory. Reason is I found a tailgate for sale that does not have the rear camera option but it's the same color so no painting would have to be done.
Old 06-28-2012, 08:17 PM
edjunior's Avatar
I don't know if the cutout is the same or not. I am kinda curious though, isn't your insurance paying for this? I would think they would.
Old 06-28-2012, 08:25 PM
caddy's Avatar
Took truck to insurance for repair quote. Their estimate is about 1k short of what my dealer quoted. Insurance was going to install used part just paint to match. Was trying to see if I could do it myself and try and not take the deductible hit. I know some shops would not charge you the deductible so they could get your business also. Would like to find one that would have that arrangement.
Old 06-29-2012, 07:56 AM
jdadamsjr's Avatar
I'm pretty sure it's the same - just swap the handle/camera with the other...
now if you are talking the step and handle - NOT the same tailgate IIRC...
2007 tailgate BamaDave 2004 - 2008 F150 2 11-15-2013 05:59 PM
Tailgate mods 1978 - 1996 Big Bronco 6 05-25-2002 04:08 PM
tailgate Vampiro General NON-Automotive Conversation 7 04-17-2002 10:56 PM
Tailgates. RubberDuck 1973 - 1979 F-100 & Larger F-Series Trucks 10 08-11-2001 11:09 AM
Tailgate deadeye 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 20 02-01-2001 11:50 AM
Tags
1999, 2009, camera, city, f250, ford, oklahoma, step, stolen, tailgate, tailgates
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
