2005 Explorer Diagnostics Questions - Ford Truck Enthusiasts Forums
Old 06-24-2012, 08:47 AM
Kristillball Kristillball is offline
Kristillball is starting off with a positive reputation.
I have a 2005 Ford Explorer and a few days ago it wouldn't start, it just clicked and the lights flashed. I put it on a charger overnight and it started right up. I took it to Autozone and he tested the starter, alternator and battery and said everything was green. It was fine until yesterday when I started it up and it ran a self test and gave me:
Ignition Key B
Serial # 00075194
Part # 4L2T-10849-CK
Diagnostic Trouble Code : 9318,9352 and D900
I looked through my manuals and can't find anything with codes. My friend says batteries don't last long in Florida, I have only been here a year from Michigan. I bought the truck in 2008 and have never replaced the battery. The guy at Autozone was reluctant to sell me a battery because he didn't think I needed one. I feel like such a girl......but does anyone have any advise? I have never had any problems with this vehicle.
Thanks to anyone who can help!!
Old 06-24-2012, 09:08 AM
steve(ill)'s Avatar
steve(ill) steve(ill) is offline
steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.
If that is the original battery, you are past due. Change it out and problems will be gone.
Old 06-24-2012, 09:32 AM
Quote:
Thank you!!
Old 06-24-2012, 11:37 AM
explorerjwd explorerjwd is offline
explorerjwd is starting off with a positive reputation.
My 94 explorer battery lasted 10 years until I moved from Connecticut to Florida in late 2003. The battery was replaced in 2004 and again in 2009. I expect it will be replaced again in two years. If you go to Advance Auto they will sell you a battery, replace your battery and dispose of your old battery, all for the price of a new battery. It also appears my 1999 Ford Taurus is on a 5 year battery replacement cycle. It's battery was replaced in 2004 and again in 2009. The folks at Advance Auto told me I am lucky to have batteries last 5 years.
Old 06-26-2012, 11:53 AM
thank you!!
Old 07-29-2012, 11:08 AM
Today I replaced the battery in my 94 Explorer. The battery, installed in 2009, lasted 3 years. I noticed a slight starter hesitation when starting twice on Friday. Saturday afternoon I thought I would see how it started and all I got was a few clicks of the starter solenoid. Checked the battery voltage = 12.8 volts. When running after a jump start the alternator was producing 14.3 volts. Checked battery drain rate with engine off and got .034 volts. Left the hot cable disconnected and the ground cable connected overnight. The next day the battery was dead. Evidently an internal short within a very heat soaked Florida battery, time for a replacement. New battery and the truck is acting young again <g>
Old 07-29-2012, 12:31 PM
OOOPs = my mistake. I should have typed 3.4 milliamps instead of .034 volts.
Old 07-29-2012, 01:20 PM
aquanaut20's Avatar
aquanaut20 aquanaut20 is offline
aquanaut20 is starting off with a positive reputation.
Ah!...
WATTS that between friends... Philip
Old 07-28-2016, 04:53 PM
jks1968 jks1968 is offline
jks1968 is starting off with a positive reputation.
I have an 2005 Explorer. It died while driving last week. Tried starting it, got clicks. Tried jumping it, got clicks. Towed it home. Had battery tested, tested bad. Replaced battery with new one today. Turned key........got clicks. Any help? Oh, got the 9318, 9325, and D900 diag. codes as well as 5284. I know those first three deal with some sort of cluster and the last one some type of oil press. switch.
Old 07-28-2016, 11:39 PM
shorod's Avatar
shorod shorod is offline
shorod has a very good reputation on FTE.shorod has a very good reputation on FTE.shorod has a very good reputation on FTE.shorod has a very good reputation on FTE.
Welcome to the forum!
Are you getting "clicks" as in a rapid series of clicks, or "clicks" as in a single solid click each time the key is turned to Start?
If a rapid series of clicks, that's indicative of a starter solenoid that is not getting enough current to stay engaged. If this is the case, I'd suggest you confirm the battery cables are in good condition, are clean, and tight on the battery terminals. The cables should be formed cables, not stripped wire with battery clamps that bolt on to the stripped cable. Those are intended for temporary use and have a tendency to allow the copper to corrode and not make a good connection with the cable clamp.
If it's a single solid click, that's indicative of a starter solenoid that is engaging but a starter motor that doesn't spin. You will likely need to replace the starter motor assembly or rebuild it if this is the case.
-Rod
Old 07-30-2016, 11:50 AM
os1kne os1kne is offline
os1kne is starting off with a positive reputation.
I suspect that changing the battery will solve the problem. Shorod's suggestions are solid, and should help you resolve if the battery doesn't fix it. (Pretty sure you need a new battery regardless.)
Calling out the battery experts tseekins 2015+ F150 22 11-13-2016 06:43 AM
Starting Anomoly djousma 6.7L Power Stroke Diesel 10 10-18-2015 12:05 AM
STRANGE ISSUE 1998 F-150, 4.2L V6 Starter issues 98F150on33s 1997 - 2003 F150 6 11-26-2014 11:28 AM
'97 4.0 Ranger Check Engine Light-NO CODES Supercab Ranger & B-Series 6 04-25-2011 09:28 AM
2004 Ford Explorer 4.0L Hard Starting tsedgar Explorer, Sport Trac, Mountaineer & Aviator 0 10-18-2010 11:14 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
