cleaning up the inside
I took out the seat, old carpet, and gas tank from the uni i picked up in Connecticut (previously was in upper Idaho)
lots of rust, but very few holes.
here is a video...I have other videos on there too if you are bored.
1961 Ford F100 Unibody-April - YouTube
it gives me something to do, but I'd really like to have a garage to put it in so I can work on it.
Cheers
Gregg
Cheers
Gregg
got the front clip off. were all front axles the same from 61-64 f100 and F250? mine have some extra humps to them and the drivers side has been broken off and rewelded ontop of the axle rather than bolted through it.
lower shock mount is welded in the wrong position. any good ideas as to how to fix this?
Greg
That axle is an Abortion. AKA junk
It is defiantly not a correct axle for a 61 to 66. and yes the F100 and 250 share axles.
it looks similar to this 57 to 60
http://i177.photobucket.com/albums/w...1272123660.jpg
I have a 2 spares here if you need a good one.
Garbz
Garbz
Hey Dave, I found a casting number on the front Axle. 3711410GM11
a google search on "3711410 axle" says it's for a 1955-1959 3/4- 1ton chevy truck. my front has 6 leafs.
What the hell man. Ha.ha
the rear is an eaton HO52 or Eaton HO72 out of a chevy from the 50s to 1972. 4.10 or 4.56 gears.
found an image of it online, has the same bumps
has the bumps on it. Hey looks like I can add powersteering! haha
Power Steering 1947-1959 Chevy and 1948-1956 Ford pickup trucks.
At least he hasnt found any toyota parts yet! Or worse..... Dodge. Hahahahahaha
Good enough of a project tho. If i were you id just cut out as much of the rust in the cab as you could and reshape some 1/2 inch sheet metal to weld down. I helped a cousin do this with his 70 f350 napco 4x4 truck. It was a ex fire truck for the rockies and the rust must have corroded a few hundred pounds of metal on that truck. It was a simple enough plan if you have the time and tools. Also if you do do that weld a few extra crossmembers under the newly created floor
hail destroyer
04-29-2016 05:03 PM
Rossta86
42
12-14-2010 12:11 AM
impalaslayer
10-17-2010 05:42 PM
