Gutting the Cat Converter - Ford Truck Enthusiasts Forums
Old 06-24-2012, 07:41 AM
granny_rocket's Avatar
granny_rocket granny_rocket is offline
granny_rocket is starting off with a positive reputation.
I think I have an aftermarket cat converter. Since the emissions equipment is already gone off my truck and I have an edelbrock carb the cat is pretty much useless. For all I know too it might be original and clogged up. Is there any benefit to gutting the cat even it its not "clogged"???
I just don't want to get into gutting it and run into problems with the exhaust. Exhaust work always seems to be a can of worms to me. You touch one thing and it becomes a major project. Maybe its just me but rusty pipe never goes over well.
Thanks!
Old 06-24-2012, 09:33 AM
86fordtruck's Avatar
86fordtruck 86fordtruck is offline
86fordtruck has a good reputation on FTE.86fordtruck has a good reputation on FTE.86fordtruck has a good reputation on FTE.
If the cat isn't clogged, I would see no benefit in messing with the catalytic converter. If it is clogged, you should replace it with a high flow aftermarket unit. Cats were required after 74, and if your vehicle came with one, federal law requires it be present to be street legal.
Old 06-24-2012, 10:12 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
The truck is not street legal now, since all the emission parts, except the cats have been removed, and...
First cats were installed in 1975, but not all trucks came with them, as it depended on the series, individual states emission laws, GVWR's. CA yes in some cases, other states, I dunno.
If the muffler is clogged up (not the cat, as they usually don't clog up), you will know it, unless you are deaf.
Peeps in the 1970's removed the restrictors in fuel filler tubes that only gas station unleaded fuel nozzles would fit into. Back then there were two sizes of nozzles, leaded fuel nozzles ware larger in diameter.
They then assumed they could use leaded fuel. Fine and dandy unless cat converters were present. The lead in the fuel melted the charcoal in the cats, shoved it into the muffler.
Before too long, their vehicles sounded like vacuum cleaners headin' on down the road.
Old 06-24-2012, 01:09 PM
fellro86's Avatar
fellro86 fellro86 is offline
Iowa Benevolent Dictator
fellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud of
Cats can become restricted when they melt a bit, mostly due to improper fueling. They don't always break up and pass through the exhaust, may times they simply melt, which closes the passages in the ceramic structure. As far as legality goes, if the original emissions equipment was not maintained on the motor, the cat is a moot point, and may have melted due to improper fueling and lack air injection of the emissions system.
Old 06-24-2012, 01:46 PM
IntheTrees's Avatar
IntheTrees IntheTrees is offline
IntheTrees is starting off with a positive reputation.
Why not just replace it with a piece of pipe?
6.0L Cat Alex332 6.0L Power Stroke Diesel 24 04-03-2016 03:47 PM
MBRP turbo back exhaust with gutted cat vs cat delete pipe sound Pridnjoy 6.0L Power Stroke Diesel 5 04-13-2014 12:09 PM
Which exhaust to go with FordYoungGun35 1987 - 1996 F150 & Larger F-Series Trucks 3 12-10-2012 01:24 PM
Barely passed emissions test... Please advise me on how to clean up emissions The assassin Blevins 1994.5 - 1997 7.3L Power Stroke Diesel 19 03-11-2011 05:55 AM
Who has "gutted" their cat? chixdigit 6.0L Power Stroke Diesel 45 06-28-2006 10:03 AM
Tags
68, audio, broadcasting, bullnose, california, cat, catalytic, converter, ford, gutted, mybb, northern, powered, public, remove, trucks, v10, vbulletin
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
