Coolant loss '85 351W HO
Old 06-24-2012, 01:28 AM
XLTSIXPACK's Avatar
XLTSIXPACK
XLTSIXPACK is offline
Appreciate any thoughts on the following: I've replaced the water pump,thermostat, and intake gasket on my '85 351W HO (all oem/ told the intake was leaking). Before reassembly, there was no sludge in the valve covers, valley, white smoke from the exhaust, or oil visible in the anti-freeze- appears coolant entering the combustion cycle. After reassembly and several hours later started to misfire,lost power, then ok to ease home. When home I popped the hood - no pressure in the cooling system and low after removing the rad. cap. While replacing the intake gaskets only applied RTV to the end/side junctions as specified. No leaks otherwise inc. heater core. Thanks.
Old 06-24-2012, 07:32 AM
Franklin2's Avatar
Franklin2
Franklin2 is offline
Received 1,675 Likes on 1,354 Posts
A miss-fire indicates the coolant is shorting out one of the sparkplugs. I would pull them and see if one of them has a bunch of green crud on it. If it does, then that's where the coolant is going, and it could be a head gasket or a small crack in the head.
Old 06-24-2012, 09:04 AM
ctubutis's Avatar
ctubutis
ctubutis is offline
A leakdown test wil help you isolate the problem.
Old 06-24-2012, 02:28 PM
Gary Lewis's Avatar
Gary Lewis
Gary Lewis is offline
Posting Legend
You can get a test strip from the parts stores that react to products of combustion in the coolant, which might be easier than a leak-down test. And, some times the leak-down test doesn't show a loss to the cooling system, or vice versa, as sometimes you don't have a leak until you get the engine hot. My 351W had a blown head gasket but it wouldn't leak until I got about about 40 MPH.
tomsteve
1983 - 2012 Ranger & B-Series
02-24-2014 06:31 PM
metal13x
1997 - 2003 F150
02-26-2008 08:16 PM
84f250460
01-21-2007 05:04 PM
Greg_nw
08-23-2003 11:56 AM
95xltmud
07-02-2002 08:17 PM
Quick Reply: Coolant loss '85 351W HO
