Is it the brakes, the ball joints, the steering linkage, or all of the above?
I was driving home from work today, heading down a gentle hill at about 35 mph. I tapped the brakes and the entire front end started to violently shake and shudder like I have never seen before. Carefully slowed to a stop, and the shudder subsided, and I drove home with no more problems.
This is the 2nd time in a month that this has happened, and the first time it was so bad I thought I had a blow-out. The truck is now all but garaged until I get this rectified.
Being 33 years old, and god knows how many miles, Im sure something needs to replaced at this point. The question is, brakes, ball joints, steering linkage, one or more of them, or something else entirely?
So I just got the truck off the stands, and its not so good. There is a surprising amount of movement in both wheels side to side without effecting the other, or the pitman arm. I can also lift each one just a bit with a 6 ft crowbar.
Conclusion I have come to is that it should all be replaced. They appear to be all original parts, so 32 1/2 years isnt too bad, but Im afraid of replacing one part, only to have something else fail a short time later.
I had some money saved to replace the skid strips and bolts in the bed with stainless, and Line-X the metal and rails on the bed, but I suppose safety takes precedence over pretty.
I just ordered all new steering linkage,Dana Spicer Ball Joints, Dana Spicer front axle u-joints, alignment bushings, wheel bearings, traction beam bushings, radius arm bushings, Borgeson steering shaft and steering box rebuild kit from Bronco Graveyard for $750.
Looks like the work on the bed will have to wait till next year.
80FS, I had to + rep you for that great quote in your sig.
It reminds of a few other sayings, like "if it can't kill ya, it ain't a sport" & "Baseball, football, basketball, and most other games, only requires 1 ball".....
Sounds like you have quite a bit of parts, with varying degrees of slack. Added together, and death wobble here we come......
Yep. Unfortunate case of many things failing a little, not one failing a lot. But like you said, I'd rather be spray painting my bed than laid up in traction.
How bad is your rust? Depending on what you're looking for there's some cheaper DIY options that can provide some level of protection.
I was looking for a truck to do depot/dump runs and camping when I saw this one on eBay. Same 80/81 front end, blue exterior, and god-awful blue interior, but it was twice my budget. After spending 5 straight days looking at the posting half hoping it would be sold to take away the temptation, my wife told me to "just buy the stupid thing before someone else does and you regret it for the next 50 years." While I don't need to be told twice, I did correct her on the "stupid" part. Two things I will never sell in my life are that truck, and the ruger 10/22 my father gave me when I was 12.
My father bought an 81 F100 (2wd, styleside, I6 3spd manual, radio delete, bumper delete) new when I was a kid. I grew up in that truck and distinctly remember riding in it 4 across with him and my 2 brothers. I then learned to drive in it, and even back up that bitch of a driveway with the cap on it using nothing but the sideview mirrors. Sadly 6 months after getting my license I put that truck through a telephone pole and into a tree driving home after a light snow.
I was looking for a truck to do depot/dump runs and camping when i saw this one. Same 80/81 front end, blue exterior, and god-awful blue interior, but it was twice my budget. After spending 5 straight days looking at the posting half hoping it would be sold to take away the temptation, my wife told me to "just buy the stupid thing before someone else does and you regret it for the next 50 years." I dont need to be told twice. Two things I will never sell in my life are that truck, and the ruger 10/22 my father gave me when I was 12.
Doing it all at once is the best way if you have the money. Once you get down in there to replace the front axle u-joints, you will tell yourself you do not want to do this again. You also should go to Harbor Freight and get their cheap balljoint press to get the balljoints out. Also buy a cheap pickle fork there too.
The ball joint press and pickle fork are handy to own, but can also be rented thru most parts houses. I'd rather rent a tool that I hope to NOT need again for 25-30 years......
There are two types. The ones like you are thinking of are a specific degree. There is also an adjustable design. These use an inner/outer sleeve, and can allow for any amount of adjustment within their design limits, like -2.5 to +2.5. Pricier, but worth the extra funds.
