Replaced side gas tank, now I need a filler hose
I just replaced my gas tank but I need to find the filler hose. I dont understand exactly what I need, I know there is the outer rubber house and the inner plastic hose but cant seem to find much information on where i can buy these parts new or if I even need the inner hose. Does anybody have any experience with this?
Welcome to FTE
Please, when asking questions, list all the pertinent details.
What year is the truck, what series? Which tank did you replace, mid-ship (in front of the L/R wheel) or aft axle (behind the L/R wheel)? Is it a plastic or steel tank? Styleside pickup?
One neoprene rubber filler hose does not fit all...and on some, the hose is not available by itself, as Ford only supplied it with fuel filler tube.
So, it could take over an hour just to fill one tank, cuz almost as much gas sloshes out, as you're tryin' to put it in, I kid you not.
With gas at 4 bucks a gallon, it could cost 30-50% more to fill one tank, unless you get your sponge out, use it to sop up the sloshed gas layin' on the pavement.
Welcome to FTE
Applications: 1981/83 F100 / 1981/89 F150 / 1981/89 F250/350 without DRW, without two piece filler tube.
Last MSRP: $60.29 / Dealer net cost: $40.19.
MEREDITH MOTOR CO. in Meredith NH has 1 = 603-279-4521.
TASCA FORD in Cranston RI has 1 = 401-681-1360.
LINDSEY FORD in Wheaton MD has 1 = 301-949-4060.
BEASLEY FORD-LINCOLN in York PA has 1 = 717-755-2911.
DOTTS MOTOR CO. in Clearfield PA has 1 = 814-765-9681.
ADAMSON FORD in Birmingham AL has 2 = 205-271-4700.
VINTAGE PARTS in Beaver Dam WI has 82 = 877-846-8243.
Call around for the best price, obsolete parts prices can vary wildly from one source to another.
get a filler from a late 80's truck.it's a different style .only mod is to get rid of inner metal tube in gas tank inlet(holds the little inner flexible plastic tube).i just carefully used visegrips and small prybar to work the spotwelds loose.older style has inner tube as breather and outer metal as filler but newer is reversed with the bigger inner as fill.WAY faster fill now
